Results 1 to 13 of 13
    May 2013
    6
    Emaxx Steering servo
    I have a 2055 model traxxas servo, its not together but i have all parts, can some post a pic of what it looks like internally, but together, the gears of course, thanks!
    Jul 2012
    Yakima, Washington
    1,420
    ok i get it now!
    May 2013
    6
    No, i just got it in trade from craigslist, but servo gears need to be installed, i dont know what order they go in
    Jul 2012
    Yakima, Washington
    1,420
    May 2013
    6
    Ur a life saver, thanks!!
    Grrr cant seem to get the peices to go correctly, it wont fit into the mounted spot
    Sep 2010
    Chicago, IL
    1,970
    Wiggle em and make sure everything is meshing right? post up pics of issue?
    "American Muscle beats import any day of the week"
    May 2013
    6
    Sure, any good sites to host photos from my cell, im using that
    http://www.imgxc.com/image/DZ1x7W
    http://www.imgxc.com/image/ZfYrcv
    http://www.imgxc.com/image/PYl15Z
    Ok, i got it, servo is hesitating to turn right, it like pulses, somes times also when i turn left, a pulse, any ideas?
    Sep 2010
    Chicago, IL
    1,970
    Do you have another radio to try? Not saying its the radio, but those old ones can be a pain. Or your servo could just be dead. I try to avoid opening them up at all costs cause i can never get em to work right again.
    u.k.
    1,770
    If you lived in the uk i would of sent you one of my old servo's. I just use a cheap 4th generation clone from fleEbay.
    Problems.The manual's good starting point. Simple
    Mar 2003
    Wherever the road takes me.
    36,790
    For starters, you are having assembly issues because you're assembling the servo backwards (in a sense). You should install the gears on the main servo body, don't install them in the servo's top; this will make life much easier for you. I also would recommend flipping the chassis over and removing the four screws that hold the servo's top to the chassis. From there, install the gears on the main servo body (the largest part with the wires coming out of it) and reassemble the servo's case.
    If it's pulsing, you may have turned the adjustment knob in the servo (depicted in the diagram posted above as #11, the sensor pot). Do you see the large shaft with the two flat sides in your second picture? If that is turned even just a tiny bit when assembling the servo, the servo motor will be activated. Whenever I rebuild a servo, I plug the servo into the receiver and power up the electronics; doing that will allow you to know whether or not that shaft has been turned (you'll hear the servo's motor and see the gear(s) spinning). Turn that shaft until the motor stops (it can be finicky, so be patient) and then install the servo gears.
    Good luck!
    May 2013
    6
    Ok, will give it a shot, if its still pulsing im going to replace it on saturday, along with the batteries, it came with 2 duratrax 1500mah battieres, think im gonna go with 4000mah
    Ordered 4300mah batteries and purchased servo 2056
    Mar 2003
    36,790
    Weren't able to get it back together, eh? I'd keep trying, you'll get it eventually. I know that I had a heck of a time the first couple of times I did it. If you do manage to get the old one back together properly, then you'll have a backup servo.
    May 2013
    6
    Yes got the other servo back together, so now i have two.working.servos, it ended up being the.radio was faulty
