Results 1 to 9 of 9
Thread: bogging prob
    Middle River,MD
    84
    bogging prob
    Idle is set ap paperclip hsn is 3.5 out and lsn is stock the prob is when I turn a corner or drift. Speeding out I bog and even after a few speed runs wants to shut off any insight? Recently broken in 3.3 prob temp is 76 outside hottest the engine read 220
    Jato 3.3,Slayer pro
    2,215
    What happens when it is idling for about 5 secs and then you mash the throttle? does it take off fast or does it bog with lots of smoke?
    Dec 2008
    Gettin' Lucky In KY
    3,876
    Read my reply in this thread. I described bogging characteristics in it. Hopefully it helps.
    http://traxxas.com/forums/showthread...-the-hobby-guy
    Middle River,MD
    84
    Think bogging is no longer an issue however it won't idle as soon as I let go of the trigger it dies even after several high speed runs also when I'm starting it the wheels spin is this normal? Towards the end of the run when I started it the rpms went way hight I hit brake it slowed hit gas a little and uda thought I pulled trigger all the way idk I'm confused here
    Jato 3.3,Slayer pro
    Middle River,MD
    84
    How many turns out from closed is ur lsn
    Jato 3.3,Slayer pro
    Toronto
    168
    Check the clutch shoes, spring might be broken or stretched.
    Jato 3.3 Pede 2.5R Rusty 3.3
    Middle River,MD
    84
    Jato 3.3,Slayer pro
    Apr 2013
    8
    I had a similar problem although I wouldn't call it bogging, it was more like the idle was set too low. Here is the section of the manual that helped me solve the problem. Note: the idle slide is that little slide that rests against the servo arm and is loosened with a little hex set screw.
    Idle Speed Adjustment
    Once the high and low-speed mixtures have been set, reduce the idle
    speed to the minimum reliable idle speed. Remember, this adjustment
    should be made while the engine is running at normal operating
    temperature.
    1. Turn the throttle trim on the transmitter so the brakes are
    applied (note its original position). This ensures that the throttle
    slide is resting against the idle adjustment screw.
    2. Turn the screw counterclockwise to reduce the idle speed, or clockwise
    to increase it. The idle speed should be set as low as possible while still
    maintaining reliable running characteristics.
    3. Reset the throttle trim on the transmitter to its original position.
    Middle River,MD
    84
    Ok I opened up the clutch today and ofcourse the spring was done so I replaced that and bam solved my spinning wheel issue and idle problem too it seems I only ran half a tank through it but it did fine hit 2nd gear no prob stopped and held an idle thanks guys for all ur insight
    Jato 3.3,Slayer pro
