Results 1 to 16 of 16
    Bethlehem, PA
    248
    Question Gear change needed if UNlocked?
    Hey Guys,
    Ive been running my XO-1 for almost a week now, and I just love it. Ive ran it on 4S at first, then I ran it on 5S and this weekend I ran it at 6S (locked)...
    If I UNlock it, and I only want to try to go maybe 70 to 75 MPH - do I need to do a gear change or can I run the XO-1 unlocked with the stock gear and not have any issues? Again, I dont care to do 100MPH - I just dont want to mess with the gears, because I do alot of drifting, and not just high speed runs.
    Thanks!
    Mayor VXL
    ERevo|XO-1|Summit 1/8th
    Central, WI.
    235
    Yes you need a gear change. A 21 tooth pinion will get it to 77mph on fresh charge then it will go down to about 72 mph as batterys get low. 14 tooth won't cut it.
    Traxxas Employee TireSlinger's Avatar
    Sep 2010
    487
    I use a 24T gear on mine and am very happy. Its exactly in the middle of the factory and 100mph gearing.
    If you're going to use it for drifting I would probably keep the gearing a tad lower than 24. The 21T suggested above would probably be just right.
    Bethlehem, PA
    248
    Guys - can someone please provide me with a part # for the 21T pinion?
    Thanks!
    Mayor VXL
    692
    i dont think traxxas offers one , you will have to get it from a differnt supplier . go on ebay or google , Mod1 21t pinion 5mm shaft and your find all kinds of options .
    Bethlehem, PA
    248
    Could anyone tell me which they would choose:
    Castle Gear (steel): http://www.rcplanet.com/ProductDetai...CSE010-0065-12
    Novak Gear (steel): http://www.rcplanet.com/ProductDetai...ctCode=NVK5115
    Team Durango (aluminum): http://www.rcplanet.com/ProductDetai...de=TDRTD310357
    Mayor VXL
    190
    Go with castle gear. In my opinion they make em the best. I deffinatley wouldn't go with aluminum though. I had aluminum and it bent in half. No joke.
    NY
    16
    Quote Originally Posted by TireSlinger View Post
    Where did you buy the 24t?
    Sep 2010
    487
    I honestly do not know, a friend gave it to me. One of those random loose parts in the bottom of the tool box. It is black with a white "24" stamped on it, no manufacturer is listed. There are many many many companies that make gears. You need a mod 1 pinion gear with a 5mm opening for the motor shaft. From what I've found most all 1/8 pinions for buggies and monster trucks will work. Make sure it is a mod 1 though, the mod .8 will not work.
    Bethlehem, PA
    248
    TireSlinger - would this 24T pinion work DSMing91?
    http://www.rcplanet.com/Xtra_Hard_5m..._p/rrp8724.htm
    Mayor VXL
    Central, WI.
    235
    NY
    16
    Thanks guys.
    NY
    16
    Thanks. I will look around.
    NY
    16
    Sep 2010
    487
    As long as it has a 5mm motor shaft opening and a "mod 1" or "1 mod" tooth size you should be good to go. Unfortunately I cannot verify specific non-Traxxas items or brands that will or will not work.
    15,694
    I can note that a 5mm-bore Integy pinion that a friend bought for his Summit was not bored 5mm all the way through. It tapered to somewhere between 4.8 & 4.9mm and therefore would not fit on a 5mm motor shaft. I'd avoid them.
    Alt-248 on the number pad =
