    3,127
    Just a few quick summit tips l/ helpful links - please feel free to add more
    Faq
    hub / hex Slop Removal and elimination 17mm
    (composition)
    http://traxxas.com/forums/showthread...01#post5488801
    (pavement surfer)
    http://traxxas.com/forums/showthread...-17mm-adapters
    pix
    pix (NeoMaxPro)
    #2 (Klimpen717)
    http://traxxas.com/forums/showthread...ing-(pictures)
    how to set up traxxas telemetry (MAYOR VXL)
    http://traxxas.com/forums/showthread...e-amp-Voltage)
    How to narrow a set of wheels (Tmaxxed)
    http://traxxas.com/forums/showthread...-set-of-wheels
    pix
    How to strengthen your differentials
    # 1 Shimming
    http://traxxas.com/forums/showthread...the-third-time
    # 2 aftermarket steel gears and aluminum diff cups
    http://traxxas.com/forums/showthread...=diff+aluminum
    http://traxxas.com/forums/showthread...inum-diff-cup)
    #3 cracked bulk head
    http://traxxas.com/forums/showthread...after-shimming
    home made brake lights
    http://traxxas.com/forums/showthread...g-brake-lights
    new evx2 - issues addressed
    http://traxxas.com/forums/showthread...VD-With-NIMH-s
    http://traxxas.com/forums/showthread...vx-2-for-lipos
    How to make tires chains
    http://traxxas.com/forums/showthread...ke-tire-chains
    how to make a scale size summit (summit LT)
    http://traxxas.com/forums/showthread...t=summit+scale
    http://www.rccaraction-digital.com/r...000&pg=54#pg54
    http://www.rccaraction.com/blog/2011...-action-video/
    http://traxxas.com/forums/showthread...Traxxas-Summit
    summit stock rims
    #1 de-chroming them (by Jimmie Neutron)
    Here is how I did it...
    1) Cleaned the dirt off
    2) Took the rings off
    3) Cleaned more dirt off
    4) Sprayed it down with yellow cap oven cleaner
    -Used WalMart brand first...
    did not get all the chrome off, but could be due to my impatience (2 hours)
    -Bought a can of the real thing...
    Easy Off with the yellow cap then sprayed them down and left them overnight
    I did reapply a few times during the night
    5) Hosed them down
    6) Picked at a few spots with a tooth pick
    7) Washed them with soap and water in the bath tub
    8) Let them dry outside
    9) Installed the rings
    pix
    #2 adding 40 series tires to stock rims
    http://traxxas.com/forums/showthread...light=slingers
    installing a bec for those stronger servos
    http://traxxas.com/forums/showthread...C-install-Help
    http://traxxas.com/forums/showthread...Servo-Amp-Draw
    adding weight to your front wheels for better climbing
    http://traxxas.com/forums/showthread...wling-traction
    tranny slop fix
    http://traxxas.com/forums/showthread...rivetrain-slop
    http://traxxas.com/forums/showthread...ranny-slop-fix
    http://traxxas.com/forums/showthread...slop-reduction
    http://www.rccrawler.com/forum/gener...mit-trans.html
    please feel free to add more tips
    MAN, Use Common Sense.
    Outside? THERE IS NO BOX !
    Feb 2010
    Williamsburg, KY
    229
    maybe something to add to the cut hubs slop fix, Z680 is the hpi part number for the wide wheel nuts alone. saves a few bucks i guess
    crawl-bash-swim. The Summit does it all.
    Upstate NY
    83
    I hope I'm not the only one that has had axle/CV pins slide out a little and break the end of the axle tube. Here's a simple fix for all 8 of them. Sorry no pics for this.
    The little groove in the center is too shallow. I used a Dremel with a cut off wheel and ground a small flat spot in the center of the pin for the grub screw to seat better. Just remove the grub completely re-insert the pin aligning the new ground flat spot with the grub hole and re-install the grub screw.
    On a side note if you have had the pleasure of breaking spiders and have purchased factory replacements (PN# TRA5382X), the pin in the kit that the spiders ride on, will also double as a CV pin if you grind a flat spot in the center for the grub as well. Handy if you've lost an original CV pin. Also in that same factory spider gear kit there are hardened output shafts. If your handy and have access to a lathe you can drill a 3mm hole (carbide bit highly recommended) through them and cut off the shaft for a set of homemade hardened spiders. (Shim as necessary)
    They work GREAT!!! And since they were unused spares from the spider kits I had bought they were basically free! I have not had an issue with them yet even under brushless power.
    3,127
    High clearance A arms by mark man
    http://traxxas.com/forums/showthread...earance-A-arms.
    San Jose, Costa Rica
    704
    Hey Noir...
    On the "how to make a scale size summit (summit LT)"
    The first and last links are repeated.
    Sl4sh MM2
    T-Maxx 3.3
    Summit 1/10
    Sl2sh VXL
    Newcastle, Australia
    968
    Jimmie Neutron's Speed Guide: Rear Differential Housing Removal
    http://traxxas.com/forums/showthread...ousing-Removal
