    15
    Question Tight gear mesh OS.21 mounting help
    So when I tighten the motor mount screws down the motor rises in the mount causing the mesh to be way
    to tight, like its difficult to spin, I can get the mesh to have some play but the motor isn't tightened all the way causing it to wiggle in the mount slightly. any tips to get the motor mounted with correct mesh?
    Mar 2007
    Michigan
    293
    Sounds like your motor mount screws are too long.
    Putting the water on the hot stuff
    9,707
    Yeah, you shouldn't have that issue if the engine mounts solidly on the mount.
    15
    im still using the stock mount screws though, thought this motor was a drop in lol
    Gurley, Alabama
    766
    I'm not sure about the Revo motor mount, but on my Jato there are spacers that go on top of the mount between the motor and the mount. Maybe something like that is missing.?.
    Oct 2005
    South Florida
    18,515
    I'm thinking there's something with the flywheel not sitting on the crank right throwing everything off....
    Robin Williams
    He will be greatly missed...
    15
    ive discovered that i can change the angle of the mount From the manuel-The ideal spur gear/clutch bell gear mesh for
    Revo is 0.1mm. To set the gear mesh, place a
    strip of standard letter/A4 size copy or printer
    paper (about 0.1mm thick) between the
    mating teeth. Loosen the two horizontal
    engine mount screws and slide the engine
    mount up to push the clutch bell gear against
    the spur gear so that the that the paper is not
    too tight to pull out or too loose that it will fall
    out. Tighten the two horizontal engine mount
    screws securely. When the paper is removed,
    you should feel only the slightest amount of
    play between the gears (almost none) and
    there should be no binding or friction.
