    Apr 2013
    13
    I Just Bought A Traxxas Brushless E-Revo...RC Newbie
    I'll apologize up front, as I have absolutely no clue about this stuff and I obviously have a lot to learn. I bought a new E-Revo brushless with the Mamba motor, and when I opened it up I was expecting that it already had the lipo batteries/chargers, but I must've picked up an older model (5608) as it has the Nimh batteries and no charger...That was a downer; I was really hoping to charge up the batteries and make a few runs when I got home. Anyway, do you guys have any suggestions on which batteries to get, which charger(s), locations to purchase, what parts to replace with stronger parts/common issues, etc. I really appreciate the input. The last RC car I had was probably 20 years ago...things have changed a bit, since then.
    Jul 2012
    Saint Louis, MO
    504
    SPC lipos are very good and a lot of us here use them. The 6500 mah 50c are about perfect. I'd stick to 4s (2x2s) as it plenty fast and plenty powerful.
    If you break axles upgrade to summit shafts.
    I have not broken anything on mine running 4s going on a few months of owning it.
    I did change spurs and pinion. Running a 21 tooth Robinson racing pinion and 56 tooth spur. It's good for about 43 mph.
    Chargers, it depends on how much you want to spend and what you want it to do. Charge more than one pack? Ability to discharge and put in storage mode? All those will cost more but I wouldn't skimp on a charger.
    I use the onyx 245 and its ok but it can't discharge but it can charge two packs at once. I use the telemetry voltage meter to run done my packs to storage voltage.
    One more thing you should get is the USB castle link so you can hook your esc up to your computer and tweak the esc or update firmware. I like to set my LVC to 3.5 volts per cell and lower brake % and set a bit of punch control.
    Also do the slipper breakin then you will likely need to tighten it to about 1/4 off from fully tightened.
    You can align your servos so they aren't fighting each other:
    http://youtu.be/kSrAvhm3b1g
    There are lots of good threads here and lots of very helpful people.
    Apr 2013
    13
    I really appreciate your help. I'm definitely one that looks at quality and function, not just price...In my opinion, the old saying, "you can pick two...good, cheap & fast" applies to just about everything; not just racecars. I'd like to be able to charge at least two packs at a time and not have to stand over it, so standby/storage modes would be great. I'm hoping that there is a charger that will charge the LiPos and the NiMH batteries, so I don't have to buy and deal with multiple chargers.
    Quote Originally Posted by tjtoed View Post
    Jul 2012
    Saint Louis, MO
    504
    I am looking to upgrade to the hitec x4 AC. It will charge 4 packs up to 6A and also discharge/storage mode.
    It has a built in power supply.
    6a is not that high but I always charge at 1c so all my packs get charged at 5A.
    Jul 2010
    Beautiful SoCal
    889
    Batteries: specpointconcepts.com
    Locations? Not Hobby People. Buy from rcplanet.com, towerhobbies.com, amainhobbies.com, thebarnfloor.com, ebay
    If you buy aluminum, DONT BUY INTEGY!
    Jesus, Lights, RC, Minecraft, LoL
    Mar 2013
    South Florida
    72
    Check your slipper clutch before you run it. Many have had very loose slippers out of the box.
    kansas
    7,820
    Have a good read thru the manual & this.
    AOD's Links Revo
    Erevo 101:
    EREVO FAQ
    Lipo, LVC, Brushless & Battery charger/charging guides & purchasing links:
    TUTORIALS
    Refer to this to setup the Mamba Monster ( MMM ) esc for maximum performance:
    CASTLE LINK GUIDE
    Refer to this to find parts, upgrades, batts & chargers etc:
    USEFUL LINKS
    And direct from Castle Creations ( the esc manufacturers ):
    MMM FAQ
    Driver's ED Manual
    LED warning light meanings
    you will need Castle link or a field card for programing the ESC, because you need to up the LVC to 3.4v per cell.
    link #3
    break in the slipper
    Slipper Clutch Break-In
    The E-Revo Brushless Edition’s slipper clutch requires a break-in procedure
    to ensure consistent operation with the extremely high power output of
    the included Castle Creations Mamba Monster brushless motor system. The
    slipper clutch has been adjusted to the correct initial setting for break-in.
    Follow these steps to ensure maximum performance and life from your
    slipper clutch:
    1. Make your first runs with the model using the stock gearing and 6- or
    7-cell NiMH packs, or 2S LiPo packs.
    2. Drive normally. The slipper clutch should slip momentarily when
    accelerating aggressively on high-traction surfaces (you will hear a
    whirring sound when the slipper clutch allows the spur gear to slip).
    3. If excessive slippage is noticed (slipping that lasts for more than 3
    seconds under hard acceleration), or the slipper clutch slips anytime
    the throttle is applied at any lever, stop driving immediately. Let the
    slipper clutch cool for 10-15 minutes. When the clutch is cool, test-drive
    the vehicle again. If you still experience excessive slippage, allow the
    slipper to cool once more, then tighten the slipper nut turn (turn the
    nut clockwise) and repeat the break-in process. Do not adjust the slipper
    clutch before it has cooled.
    4. Continue to run the vehicle and monitor slipper clutch performance as
    noted above, and readjust if necessary. When the run is complete, the
    slipper should be fully broken in.
    After break-in, the slipper clutch is ready for any type of driving, with any
    batteries up to 6S Lipo. Set the slipper clutch so it only slips for a moment
    (if at all) under hard acceleration in high-traction conditions. If excessive
    slippage is noticed, stop driving immediately. Continuing to drive with a
    loose slipper will cause damage to the slipper unit. You must let the slipper
    cool down to ambient temperature before tightening the slipper nut and
    resuming driving.
    http://traxxas.com/sites/default/fil...KC1491-R00.pdf
    welcome to the denewboobafacation......
    Apr 2013
    13
    It looks like I have a lot of reading to do! I'm a car nut, so it shouldn't be difficult to get the basics, but there is obviously a lot to it. I went to a local RC hobby shop, yesterday, and picked up a couple of 2S 6600MAH battery packs and an "onyx 245" charger, but I didn't get an opportunity to do anything except charge the batteries just yet. I'll likely take it outside and drive it a little tonight, and I'll go through the break-in process and try to make sure I'm doing everything right so I don't screw it up. I really appreciate all of the help!
