Results 1 to 23 of 23
    up north
    100
    I don't understand batteries anymore :0
    My 11.1v 3s lipo is charging up to 12.9v and my 7s nimh pack is charging to 9.7 (about) ???? Also what can each cell in a lipo battery be safely be discharged to?
    u.k.
    1,774
    Your lipo is over charging by 0.3V
    the 7cell nimh should be 10.5V (about)
    3V per cell is the absolute minimum the lipo should go down too. But there is no need to discharge them.
    Alma, MI
    12,280
    Voltages marked on the pack are nominal.
    LiPo:
    Full = 4.2v/cell
    Nominal = 3.7v/cell
    Empty = 3v/cell << You really do not want to ever empty a LiPo.
    NiMh:
    Full = 1.4-1.6v/cell
    Nominal = 1.2v/cell
    Empty = .9-1v/cell
    up north
    100
    Thanks it helps :P. now about the mah rating, when they say 6400 mah do they mean until lvc kicks in? Or is that until you completely drain the battery and reverse its polarity.
    Alma, MI
    12,280
    LiPo's polarity cannot be reversed.
    Capacity (mAh) rating is not always completely useable... depends on the quality of the pack. I have seen packs able to deliver over their stated capacity and I have seen packs not capable of their stated capacity. Discharging is not done by capacity anyway... it is done by cell voltage... and it should be that way for charging as well.
    up north
    100
    Oh ok my dad said that's what happens when discharge them to much. :P as with the mah I meant (example) at 4.2v one of the cells have all of there 6400 mah in them. Then when you start to use up the storage the voltage starts to drop. So at 3.3v when lvd cuts in is almost all of the storage gone (500 mah left of is there still half a pack worth of storage left in there?
    Alma, MI
    12,280
    Next time I run my pack down I'll report back how much mAh I used vs the stated capacity. I even have new battery coming tomorrow... or Tuesday.
    up north
    100
    Thanks .
    Alma, MI
    12,280
    Battery came in...
    Labeled as a 5S 5000mAh 40C.
    Cycled down to 3v/cell on my iCharger and balance charged it to 4.2v/cell.... 4983mAh was put into the pack.
    Keep in mind that it takes a few cycles to get full performance out of any LiPo.
    Ran it today with the ESC set for 2.6v/cell, but the ESC I was using recognizes the 5S pack as a 6S pack... which means when the pack voltage hits 15.6 the ESC reduces power to less than 50% for just long enough for you to drive the RC back to you... most of the time lol. This also means, in theory, that I am setting the LVC to 3.1v/cell... but I think the ESC must watch dipping voltage quite closely because as soon as it hits LVC cell voltages range from 3.3-3.4v/cell and 3.5-3.6v/cell 15 minutes after the run.
    Once I charge it up for a run tomorrow I will tell you how much mAh was used in today's run.
    Alma, MI
    12,280
    4724mAh back in after a run.
    up north
    100
    Thanks. I didn't get the best of results with my 6400 mah pack I ended up with ~2600 mah left unused in the pack. :/
    up north
    100
    Oh the battery is a traxxas 3s 25c 6400 mah pack
    Alma, MI
    12,280
    What were your cell voltages and what is the LVC set at?
    up north
    100
    Esc is vxl-3 so I don't know and I think the whole pack was 10.5v
    Alma, MI
    12,280
    That figures to be about 3.5v/cell.
    Are they new or old?
    up north
    100
    Fairly new, about 20 cycles
    Alma, MI
    12,280
    Something isn't right... your LVC is about where it should be. Any lower and you could ruin the pack, but you should be draining more mAh than that out of it.
    up north
    100
    Could it be because of the c rating? Because with a higher c rating you get less battery dip right?
    Alma, MI
    12,280
    The C rating is out of equation if the end voltage is 10.5v for the pack.
    up north
    100
    Oh do you think that the issue will fix itself after a while?
    up north
    100
    Alma, MI
    12,280
    Hard saying since we don't know what the problem is.
    up north
    100
    Yes, that might be a problem.
