Results 1 to 9 of 9
    Apr 2013
    4
    T-Maxx reverse help
    I've got a T-Maxx classic black trans upgraded with a 3.3. How do i set my revers? Sometimes it works ok but usually when i use the reverse it either does nothing or will go into reverse and takes a bit to go forward again.
    2,435
    sounds normal to me, haha, thats why i deleted it with the FOC kit... also a lot of times with reverse it will buck at idle, really annoying...
    your idle has to be nice and low or it wont shift properly back and forth...
    Apr 2013
    4
    Quote Originally Posted by kuskye25 View Post
    Thanks ill try to set the idle a bit lower. And does buck occasionally which is kind of annoying especially when refueling with the engine running.
    2,435
    Quote Originally Posted by T-maxxGuy531 View Post
    the bucking is the main reason i ditched the reverse on mine... refueling and tuning it just made me mad, sure it was totally doable but im a freak and if i dont like something then i hate it
    id just get my screw driver on my LSN or HSN and then BUCK... and start over...
    ive had a few other rc's with reverse... savage25 i added it, and currently my MGT8.0cc stock with it... both have rock solid reverse's never bucked, and never got stuck in or out of reverse... not sure why the maxx's is so finicky..
    Pa
    567
    Just eliminate it with FOC conversion and never look back
    566
    Lol, a good tune eliminates the buck and allows it to change to forward and reverse. When you refuel, the engine goes slightly lean and increases rpm's, in essence locking the trans in whatever gear it's in, until the engine richens back up and the idle comes back down.
    2,435
    Quote Originally Posted by Oldrcguy View Post
    yeah cept on the engines ive had in order to have the tune i like it bucked... if i adjusted the tune to make it not buck as much it wasnt to my liking... but then again different engines do things differently, maybe yours likes the really low idle... mine never have, i mean they werent high idle by any means but id have to lower it so much it would die when i let off the throttle or hit the brakes in order to make it not buck...
    Apr 2013
    4
    Red face
    I'm going to bash my maxx for a bit. I'll try to get the reverse working if not i might get the foc.
    Cocoa Florida
    3,918
    You can always do the no buck mod if you get tried of the bucking & want to keep the reverse.
    http://traxxas.com/forums/showthread...y-modification!
    Look out for the tree/crunch!
    LiPo? Naw NITRO!!
