Results 1 to 21 of 21
    Apr 2013
    17
    Brand new e-revo - Slipper Clutch or something came apart 10-15 mins into first drive
    So I ordered a e-Revo 5608 from Amazon brand new.
    I charged up the included batteries (NIMH's) and went out for my first drive.
    Breaking in the slipper clutch slowly with gradual throttle, everything was running great.
    I ran for about 10-15 minutes it seemed like and then it started to make strange noises. I drove it over to me and looked at it and noticed a little smoke seemed to be coming out of where the motor/gearbox comes together.
    I also noticed that there were shavings of black plastic all over the place inside. I shut everything down and brought it inside, pulled the cover off the clutch box and noticed that the gear when it turns wobbles. Looks like the plastic came out from inside that.
    Has this happened to anyone right out of the box? I haven't even charged my lipo's, so this was strictly NIMH's, not beating on it at all.
    I'm working with Amazon for a replacement right now as I think something was put together incorrectly (over tight, or whatever).
    Any idea what happened here, so I can take a look at the replacement to make sure i don't have this same issue?
    Jun 2010
    Miami, Fl
    6,731
    Either you smoked the slipper or the bearing on the clutch went bad, strange on a new truck, but take it apart, and inspect it.Post some pics if you can to get a better idea.
    Apr 2013
    17
    Quote Originally Posted by RC-Fan View Post
    I just took it apart a bit just to get an idea what it may be. I packed it up since it was only 1 day old, having a new one shipped out to me and sending this one back.
    I just never came across anyone who had this issue on the forum with the stock NIMH batteries. I beat the crap out of my 1/16 e-Revo VXL and have never had anything break yet *knock on wood*.
    Either way, if it was the slipper, or bearings on the clutch that went bad. I guess for the slipper it would just be replacing that, if it was bearings what kind of money are you looking at for replacement parts? Is it a common issue?
    Jun 2010
    Miami, Fl
    6,731
    It never happened to me before, on new or used trucks, so don't know how often it happens, but you will be paying more on shipping it back than fixing it. You mentioned the spur wobbles maybe it was a mistake during the assembling just a guess.
    Apr 2013
    17
    Shipping is free on both the return, and the replacement. They already put in my replacement order, ships Monday for Tuesday overnight delivery. Amazon rocks for returns.
    Jun 2010
    Miami, Fl
    6,731
    Sounds good. Did you slipper had a high pitch noise?
    Apr 2013
    17
    Yeah - It started making a higher pitch whine, that's when I stopped and pulled the cover off to take a look at noticed the smoke and shavings.
    Jun 2010
    Miami, Fl
    6,731
    That means the slipper was to loose, and when that happens the pads overheat, and they smoke. It doesn't mean that there is something wrong with the truck not even a reason to send it back, but that's your decision. Next time just tight then the slipper all the way in, and loosen it up from 1/4 to 3/4 of a turn, the ideal is 1/4 to 1/2. If you have the manual it is well splained.
    Apr 2013
    17
    The pile of plastic shavings isn't something wrong? Just my as well get a brand new one with what it costs I guess was my thinking. Instead of me having to buy the parts, pull it all apart and replace them. With the amount of plastic shavings, something surely has to be replaced? If not, it's just surprising.
    Jun 2010
    Miami, Fl
    6,731
    The slipper was loose, so the spur wobbles all around, rubbing with the spur gear cover. I guess that's from the plastic shavings came from, even the spur could get damaged as well, it could happen again if don't setup your slipper properly, it doesn't mean you got a defective truck, it is your responsibility to know how to operate the truck, and check everything before running. Read your manual before running your truck it is very helpful.
    Apr 2013
    17
    I guess i just didn't think to take the truck apart before running it the first time is all. I'll be sure to do so in the future.
    Watching a bunch of Youtube video's now to get up on things.
    Thanks for all the replies everyone.
    Jun 2010
    Miami, Fl
    6,731
    I understand your excitement to run your brand new truck, but it is better to check everything is where it is suppose to be before running, setting up the slipper doesn't take more than 2 min, and the only disassemble involved is removing the spur cover (one screw). It is not a thing you have to do constantly, but once in a while.
    Apr 2013
    50
    While it is still a good idea....Traxxas does not tell customers to take truck apart and check everything before running.... nor should they have to on a brand new truck. Slipper adjustment is recommended as routine maintenance..... after running the truck. The manual DOES state to stop driving if excessive slippage is noticed during break in. It became operator error once the slippage was noticed and operation was continued without adjustment. (Page 19)
    Page 19
    Apr 2013
    17
    Quote Originally Posted by ImageX View Post
    Page 19
    When the noise changed and sounded different (I assume the slipper making the noise, or the gear mesh not being correct) - I stopped the car to check it out. The shavings were present then.
    I will be sure to take apart the new car to check and make sure of the tightness. I'm just going to pull it completely apart to replace skid guards, bumpers, etc when I get it and to make sure everything is correct at the same time.
    Apr 2013
    50
    Yeah, not a bad idea to play it safe. Especially with this kind of power. I have a 1/16 Revo but will be buying the 1/10 in about 2 weeks. I will pay extra close attention to break in!
    Quote Originally Posted by rippinex View Post
    Adding hop-ups and LEDs on my new E I noticed the nut was almost all the way backed off. Had to tighten it about four good turns till bottomed out and set it to where it should have been?
    Sounds like someone on the assembly line hasn't been doing their job properly!
    Andover Township,NJ
    61
    Apr 2013
    17
    I got the new e-Revo in today and it drives great. I had to loosen up the slipper clutch from the stock. It was WAYYYY too tight.
    I noticed that the "pads" look like they are 100% metal now, in videos I've seen online they look black like brake pads. Mine are just straight metal. Is this a new design?
    Also, I saw people mention clutch replacements. What are the recommended models to do away with it? Does it put more stress on other components when you do replace it?
    Jun 2010
    Miami, Fl
    6,731
    Thats's great, metal pads are offered as an upgrade for the stock gray pads. Not sure if traxxas are including them on the new trucks, but that's good. Can't comment on slipper upgrades, the stock worked good for me.
    W Monroe, Louisiana
    1,993
    Yes the aluminum pads are now offered on the E-revo. The first car you got must have been on the shelf for some time.
    Traxxas has various updates to the design of the truck that have snuck in over time.
    -Upgrade to Aluminum Slipper Pads
    -Upgrade to 13mm axle carrier bearings
    -Upgrade to Lipo batteries and charger
    -Upgrade to Traxxas Link Radio
    Probably a few more im missing.
    Its All relative to your perspective.
    The Netherlands
    851
    Yep mine is from January 2013 and came with aluminum slipper pads.
    Jul 2007
    Rc Room
    1,484
    When you get the new one try it out again before upgrading it, keeping mindful of the slipper sounds. "Don't fix i, if it's not broken" type thing.
    Grab a pic and come ask us.
