    Apr 2013
    Connecticut USA
    136
    Just replaced OWB 2 weeks ago... Now it's slipping sort of.
    I replaced the One Way Bearing for my rustler about 2 weeks ago... In that time I probably pulled it about 150+ times and now it seems as it is slipping again... what do I do about this... bearings aren't cheap and I can't keep buying them...
    4,850
    Clean them in some denatured alcohol mix real good then oil it with some bearing oil or I have used some 3-1 oil to line it back and then try it. If it works good it might prolong the bearing for a little while.
    DEU 8:18 ESV
    Apr 2013
    Connecticut USA
    136
    thank you for the info!
    Norfolk, va
    1,167
    Clean it then lube it with mobile1 synthetic motor oil.
    4,850
    I did this a couple times to my owb's while I had my engines and worked good. It's good to clean them after about 10 runs.
    DEU 8:18 ESV
    Apr 2013
    Connecticut USA
    136
    I guess I'll clean mine then haha.
