Results 1 to 17 of 17
    82
    e-revo batteries
    i was wondering what batteries i should get for the e-revo brushless. 6s surely destroys tons of parts. which are them. id like to have a list of most probable pieces to break (out of the box). would 5s (or 4s) destroy as much.
    thx a lot!
    kansas
    7,820
    Brushed Revo ESC has a Max of 2/2s
    last I knew..
    82
    i meant the brushless
    so cal
    9,244
    Spc batteries are great! http://spcracing.com/index.php?categoryID=13
    I have their 5400 50c in 2s and 3s so I can run 4s 5s and 6s
    82
    what pieces did you change because of the raw the power?
    so cal
    9,244
    Summit axles are a good upgrade! Will need 4 long as they come from a summit that use two short and two long
    Ebay is good
    82
    diff?
    driveshafts?
    i know its a lot to ask but a list all the parts that might break in order of relevance
    EBAY has good stuff and prices
    kansas
    7,820
    might wait & break it then see if you need or want to upgrade.
    I would get a spare set of diffs & shims, other than that.....not much..jm2c
    so cal
    9,244
    That would be a good idea depending on how hard you bash!
    I invested in stock type diffs - stock ring& pinions cases and cups even robinson racing gears and kept breaking. Now I have a pile of it after going with the losi mod
    82
    what company do you suggest then?
    diff:
    ring and pinion:
    cup:
    shims:
    so cal
    9,244
    Try to stick with stock diffs if they hold up for you and stock ring and pinions
    HR makes a nice diff cup http://www.hot-racing.com/index.cgi?...RVO11X06;c=431
    Strc makes a good case http://www.teamstrc.com/index.php?ro...product_id=207
    Kyosho on shims(only part numbers I have)6mm 096046 8mm 096644 10mm 096647
    6
    Trying to PM you but your inbox full
    82
    Quote Originally Posted by sargeincharge View Post
    you can send a pm now...
    Apr 2013
    50
    How do you run 5s with 2s and 3s? A 3s and 2s in series? Is that ok to do? I'm just learning but I thought you're suppose to always run equal packs regardless of series or parallel?
    Louisiana
    629
    As long as its the exact battery besides cell count. Same c rating and mah and its perfectly fine
    kansas
    7,820
    also number of cycles & brand. The only reason I don't run 5s is charging, you can not charge a 2s & 3s in parallel
    you can in series.
    Louisiana
    629
    I made a custom batt. Tray for my emaxx and run a single 5s lipo.
