    Feb 2013
    Ashley, MI
    165
    Slipper clutch tightening?
    How do you tighten the slipper clutch so it works properly
    u.k.
    1,771
    tighten it then back it off a little. less than 1/8 of a turn. may take a couple of adjustments to find out what works, but it should slip a little to take the shock off the motor.
    Problems.The manual's good starting point. Simple
    western Australia
    217
    should be in your manual. basically tighten the little nut and have an allen key (hex key) on the trans side of the clutch to stop ut moving. and tighten it until you can just move the clutch by hand. thats your oem spec. but it also depends on the terrian your driving on to how muh slippage you need
    modded 3906 e-maxx
