    187
    Lost screws on MIP X-Duty CVD
    Well.. i lost some screws on my drive shafts.
    http://miponline.com/store/media/myi...inst-10130.pdf
    It's screw #99032 i'm missing.
    I'm looking at my local hardware store, and they have THIS screw set. If that's the same screws im ordering them.
    Jan 2008
    BFE, Indiana
    1,700
    Mine did the same. I have drive pin from a t-maxx in it now. It sticks out a bit more, but works and threads in nicely. A little blue lock tite goes a long way. I only say that because I to did not locktite my set screw. Im going to test the two setups. Mips original design and the tmaxx set screw pin. I like that the maxx set screw pin fits through completely instead of the sandwich style mip has supplied.
    Rustler, Bandit, Summit, Emaxx, Rally, and Alias
    187
    They are somewhere on a football field...
    Do you think it's the same pin as the Summit uses? I have a Summit here... that i can "borrow" a pin if needed.
    I also got a little surprised over the design. Didn't like the sandwich style.
    Is it this screw you use: http://www.samirc.no/products/traxxa...4x15mm-revo-6-
    Maybe this is better, with threadlock: http://www.samirc.no/products/xxas-5...-wthreadlock-4
    I did use red threadlock on the other screws, but didnt want to use red threadlock on the screws that i connect to the diff... what if i want to remove it. Blue okey, but not RED. And i didnt have blue in stock at the moment.
    Wales in the UK
    4,918
    Guys use red thread lock its what mip recommends i put mine together 2 years ago and not lost any bits at all and to take them apart use heat like a soldering iron .......peace
    Jan 2008
    BFE, Indiana
    1,700
    Yep those are in fact the exact ones I used.
    I have blue locktite so all I can say is make a run for some I guess.
    They fit nicely and seem to be a better setup/design/whatever.
