Results 1 to 14 of 14
    Riyadh, KSA
    75
    Transmission Failure
    Well, I was out running the Slayer trying to show a new guy in my company when I ran up into something and it stopped. I checked the wheels they all spin. I rev up the engine and it doesn't go anywhere. I attempted to adjust the slipper clutch and it doesn't move. I hear a noise in the transmission when I move the truck backwards. Does anyone know what I did to the truck?
    Summit
    Slayer Pro 4X4
    Grafenwoehr Germany
    1,304
    Off topic but the word "company" stood out to me lol what's your MOS?
    Or should I say was since your retired lol
    Riyadh, KSA
    75
    Quote Originally Posted by Emaxx1991 View Post
    My MOS was 63A M1A1 systems retired out of Vilseck in 2002 and have been contracting in the Middle East since then.
    Summit
    Slayer Pro 4X4
    Grafenwoehr Germany
    1,304
    Wow that's awesome I'm in Grafenwoehr! 89D EOD
    Grafenwoehr Germany
    1,304
    Quote Originally Posted by 93 Chevy View Post
    Did you get a chance to pull apart the tranny yet?
    Riyadh, KSA
    75
    Yes, the first gear on the primary shaft (5386) was stripped, and I am sure the one that connects to it is also. So Ebay here I come for the entire Xmission (for $21.00). I have yet to tear it down all the way and have not figured out what caused it to happen in the first place or what I could have done to keep it from happening again. This was the first time I did anything with the Xmission, so it was the original gearing. I am sure I had a bearing fail on me somewhere .
    Summit
    Slayer Pro 4X4
    Gurley, Alabama
    766
    You don't need a new trans. You can just replace 1st gear for $5. It comes with both gears that you will need.
    Sep 2011
    Tucson, AZ
    69
    Seems there are a few of us in Germany, I'm at Ramstein...
    Sep 2011
    Tucson, AZ
    69
    Quote Originally Posted by Mark Ball View Post
    And super easy to change, I did a center diff install with a rear brake kit all in under 45 minutes.
    Grafenwoehr Germany
    1,304
    Quote Originally Posted by Riverbluff View Post
    Sweet I was there about 2 weeks ago
    Riyadh, KSA
    75
    I am thinking about getting the complete Revo Gear Set from Robinson Racing, it is all metal. A little expensive too. I will take the transmission apart a little later on and take pictures of the carnage and try to figure out what and how it happened. Hopefully see if I can figure out how to prevent it from happening again.
    Summit
    Slayer Pro 4X4
    Riyadh, KSA
    75
    Here is a picture of my 1st gear and one of my ratio gears that is stripped. How can I prevent this from happening again?
    [IMG][/IMG]
    Summit
    Slayer Pro 4X4
    Oct 2011
    naptown
    588
    Mess with you slipper adjustment some. When I first got my slayer pro, I always had the issue of snapping the pin on the output shaft. I think I snapped like 4 of them before I finally got mine tuned in...But I also run a spool in my rear dif, so that doesn't help either...lol
    Aug 2012
    Levittown, NY
    141
    Quote Originally Posted by BomberSTi View Post
    It tells you its only for offroad use only!! lol but who listens to that
    And the steel gears are definantly worth getting, just make sure you put a little extra grease in there you'll never have to take it apart again unless for a bearing change but thats where ceramic bearings come into play they can really take the heat
    And the robison slipper clutch is awesome too no problems what so ever.
    I'm hittin' easy street on mud tires.
