Results 1 to 18 of 18
    Feb 2013
    so cal
    155
    old question, new dummie.
    i have a 2wd slash with cc brushless system. has the proline.protrac kit also. was looking to.make it more useful sence i dont go to the track any more. stuck my 2.2 crawler tires on today and it looked good. so i want to make it a pede.. whats the changes? i take it shocks are the same. different axels and arms, tie rods and stuff. difffrent frame and body mounts. same trans i think the 272? what do i need to do to make this a basher? is the frame different length? or is the pede narrower? what is likely.to break with the 3800kw bl and the big shoes? starting off with a 15/90 any good? how big of a tire can i run till the suspension gives out? thanks guys and gals!
    My posts and summit are a hazard to your health
    Minnesota
    1,306
    You really don't need to do much you can use the same chassis and run it as a longer pede. I think the a-arms are the same but you could install the protrac kit to make it even wider and just find a body that fits.
    EDIT: You already got the protrac kit nvm then
    ERBE
    Savage Flux XL
    Trail finder 2
    294
    When i made my sl2sh into a p2de to run one of those cool MJ bodies, all i bought was the chassis as i already had the protrac arms as u, and some different rod ends to change the length of the links as needed. I used the front skid and just drilled new holes in the chassis, and some 3mm lock nuts from i dont know where, heh. I had monster jam mounts on the slash for a weird body i was running so that also worked out just fine. It was a tedius swap, but pretty easy on the old wallet. Im runnin my mmp/3800 combo at 60% max power so i dont shred those small stock drive shafts, heh.
    Feb 2013
    so cal
    155
    this is what i have so.far. the protrac is on it. with the front bolts on the outer tie rod fliped.around clears the stock.2.2 tires from.my.crawler king. just a hot lap down the drive way told me i need more servo.
    Sent from my PantechP9070 using Tapatalk 2
    PM me if ya wanna bash at Greenwood Bashplex!
    13,098
    Just change the crawler tires (they look so darn good tho) with either trenchers or mashers, and you will have the best 2wd MT that traxxas makes cause its big bad and stable.
    Feb 2013
    Champaign, IL
    138
    Sorry not trying to hijack your thread, but is the protrac kit just the arms? Do they make it for the P2de or does the P4de version work?
    13,098
    Protrac 2wd kit comes with arms linkages shock towers rear carriers and short course rims.
    4wd kit comes with arms and linkages only.
    Minnesota
    1,306
    Quote Originally Posted by gojeepinawillys View Post
    Woah get some offset hex's and that thing would look like a sweet mud bogger! Need a true scale body too.
    ERBE
    Savage Flux XL
    Trail finder 2
    South of St Louis
    5,986
    Add big tires like Fr8ture and call it done. I had to raise my body mounts as far as they would go then trim an old Slash body to make it work, but it was almost a new truck when I ran it the first time. Don't forget to gear down when you add tall tires because they will raise your gearing.
    Feb 2013
    so cal
    155
    yeah iam staring out with a 15/90and will check temps from.there. iam looking at bodys and the body read you have. whats a rc with out mud?
    Feb 2013
    so cal
    155
    what size tire can i get away with. got 40s on my summit. a bit to big.
    Minnesota
    1,306
    2.8's will be a good size.
    ERBE
    Savage Flux XL
    Trail finder 2
    Feb 2013
    so cal
    155
    thanks ill look into some 2.8s want as big as i can with out realy pushing the drive line and arms. like anything its how you drive
    Jun 2010
    Springfield, Ma.
    3,359
    put some big wheels and mt body on it, see what brakes and upgrade till you have a beast!
    Jun 2010
    Springfield, Ma.
    3,359
    13,098
    Heres a vid of mine in a dirt drag from today:
    http://www.youtube.com/watch?v=NVI8koCSv4I
    You guys need to check out the masher 2.8's'...
    Jun 2010
    Springfield, Ma.
    3,359
    Im still running low-pro 2.2 mashers (cut) on 3.2 wheels. Its a darn good combo too!
    Jun 2010
    Springfield, Ma.
    3,359
    Here's some pix of the last set I did, lowest it can go without scrubbing the rims on every edge. Thought id post these sense you brought up drag racing lol.
    I haven't run it with the hemi body but I did run it like this for a whileit was fun, just something different for a week of chasing ........racing what ever comes along lol
