Results 1 to 7 of 7
    Greenwood Bashplex
    12,923
    Protrac steering link length for pede
    What is the length of the steering link itself (no ball ends) that you guys are using for the protrac suspension? I am trying to match up some blue titanium links for my diamondback build. Got the cambers from associated, but need to know the length of the longer steering links. Thanks for any help...
    2,450
    70mm is what comes with the kit, but I always thought they were a bit short on the pede. I know AE offers a pair of some ti 73mm's for a decent price.
    Greenwood Bashplex
    12,923
    I know, but the pede does not have a bel crank. So the length will be much more than 73.
    2,450
    The 70's that come with the kit do work tho. The thing about Protrac'ing Slashes and Rustlers is that they use the shorter rod ends. Pede's use the Jato ends so it works fine. I just always thought my steering links had a little too much thread showing.
    Mar 2009
    Williamsburg, OH
    2,532
    You definitely have to use the Pede rod ends for the Protrac links to work properly. If you have a Slash or Rusty then you would use those rod ends.
    Was an xl-5, now its vxl-ent!
    Greenwood Bashplex
    12,923
    So the long pede vxl rod ends on a protrac toe link? Cool.
    Mar 2009
    Williamsburg, OH
    2,532
    Yes. The rod ends for the toe/steering links are correct. The camber links are all the same. So to clarify, the Rusty/Slash use shorter rod ends due to the bell crank steering and the Pede uses longer rod ends due to the servo saver. Hope this helps.
