Results 1 to 21 of 21
    Mar 2013
    Colorado
    63
    Snaped axle yoke today
    Went to unser racings rc track today and ran for couple hours today. Everything was fine ther except for the rea body mounts destroying the body holes. On the way home stoped at an open field to chase some ground hogs around with the 3s lipo, and 10 min in snaped the upper drive shaft yolk, good thing i had already bought the fron and rear MIP drive shafts. I now have an excuse to install them.
    Wales in the UK
    5,706
    Dude use red thread lock and good tools and take your time and in a few months they will have payed for themselves...peace
    Norfolk, va
    1,167
    You should only use red Loctite if you don't plan on removing the screw or nut. It's nearly permanent.
    ERBE, ERBE, Summit, Slash 4X4, Bandit,
    169
    Easily removed with a bit of heat though, mine have served my great for the past 3 weeks! Where as a stock shaft would last me 2 minutes
    Wales in the UK
    5,706
    All you need to remove it is some heat like a soldering iron or heat a hex driver and it will come out and use blue on other parts so its easy to undo......peace
    SWFL
    217
    Someone stole my signature.
    Mar 2013
    Colorado
    63
    I did use red locktite on all set screws, but the otherday i noticed one of the set screws backed out of the upper output yoke.It stareted spinnig around the shaft coming out the side of the tranny case. I could not get the the stub shaft to come off the tranny shaft, but did get it lined back up with the holes on the shaft and relocktite and retightened. Seems to be ok, what would you guys recomened i do for that if it becomes an issue.
    Sep 2011
    SoCal
    111
    Whew... glad i got tekno's instead.
    SWFL
    217
    I had used HPI pins rather than using dual grub screws to secure my MIP shafts, but later decided to use beefier Traxxas pins (5145). The Traxxas pins were a little long, so you need to take some off of the end. Left is HPI, Middle is modified Traxxas, Right is unmodified Traxxas.
    Mar 2013
    Colorado
    63
    Quote Originally Posted by doubletapdaddy View Post
    that sounds like a great idea, thanks for the info doubletap. I will have to try that out. Sounds like it would work better than the grub screws.
    Wales in the UK
    5,706
    Thanks man the amount of people that say you should not use red makes me laugh dude hope you and your family are all good in da hood bro......peace out
    SWFL
    217
    parola di tua madre
    Norfolk, va
    1,167
    Well that's good to know about the MIPS. I've got a rear xtra duty set here that came off my slash, may put them back on or sell them.
    Wales in the UK
    5,706
    parola di tua madre
    Nice Italian bro i will word her up right now LOL....peace
    Northeastern CT
    235
    Double, does that stock traxxas pin work directly with the MIP shafts,or did you have to drill and tap to that size?
    Stampede 4x4 vxl w/ MMP/2400kv, Mini E-Revo
    Wales in the UK
    5,706
    No it will go in with no problems just shorten it as doubletap said and your good to go bro........peace
    SWFL
    217
    What he said.
    Wales in the UK
    5,706
    Grazie signore .....peace
    Northeastern CT
    235
    great thanks, im going to go that route myself now!
    Nashville, TN
    1,836
    When using the pins, it looks like only the thicker threaded side would make contact with the driveshaft. The torque would then be applied only to one side of the driveshaft. Perhaps that's why MIP went with the dual-set-screw setup.
    Is this assumption correct? Or, does it still work just fine without issue?
    Wales in the UK
    5,706
    It works better and thats not just me saying that And the mips grubs do not go all the way through like the traxxas ones do.......peace
