Results 1 to 12 of 12
Thread: Long antenna?
    Mar 2013
    Grand Rapids, MI
    5
    Long antenna?
    So I just bought an e revo vxl 1/16 brushless. Its 2.4GHz. So shouldn't I have a short antenna or am I getting that wrong? I opened the box up and seen this ugly antenna hanging there. I thought the new ones had the shorty?
    Of course my first post is in the wrong section. Sorry guys.
    Long Beach, California
    6,453
    2.4ghz only need to stand about 2 to 3 inches, cut the antenna TUBE long enough to stay inside the body and keep the rest for later use.
    | Rally GT8 Powered By CC | BackSl4sh Roadrunner |
    Mar 2013
    Grand Rapids, MI
    5
    Ok. Thanks. But I just don't understand why it has a long one. All the 2.4ghz come with short factory antennas I thought. Did I get an old left over model? It says 2.4ghz on the controller and the box.
    6,453
    as long as your transmitter say 2.4ghz chances are your reciever also 2.4ghz, your good. dont know why they include a long tube though, all i can say is to cut the tube to lenght.
    heres mine,
    Mar 2013
    17
    i left mine long bent it over and tucked the end in the cross brace of the front body tower. heated the blue antenna tube so when it cooled it keeps the curve and is safely out of the way under the body. doesn't take much heat. be wary!
    Mar 2013
    171
    What do you do with the excess wire? Do you cut it?
    Mar 2013
    17
    my antenna wire was the same length as the blue tube.
    Alma, MI
    12,281
    NEVER cut your antenna. It WILL reduce range.
    Extra wire should be coiled up and stored in the Rx box. Ideally, the wire should be extended straight up for maximum performance.
    If your antenna is the full length of the long antenna tube you probably have the AM radio.
    Mar 2013
    17
    2.4 tqi transmitter
    Apr 2013
    Ohio
    28
    Cut the blue tube long enough to keep it in side the body, and feed it through and put the black tip on to keep the wire from slipping back through, extra wire, feed it back into the water proof box or just coil in somewhere out of the way. reason some 2.4ghz is long is so it can reach the mounting positions for the tube away from the receiver. Don't cut the wire, just shove the extra in the water proof box, simple.
    Mar 2013
    11
    Did the same thing with my 1/16 summit. Extra wire is stored in the box
    Apr 2013
    Ohio
    28
    If you get a LCG like I did, tho its a hassle to change the battery, I like the longer Antenna for this reason in this pic. The receiver box is right behind the ESC on the top plate and the wire goes out to the bottom, you can see the Antenna tubing. This Chassis is a pain but worth it, tho it isn't really a LCG chassie lol.
