Page 2 of 2 FirstFirst 12
Results 41 to 50 of 50
  1. #41
    Mar 2013
    Denmark
    27
    A good idea...
    As i have six batteries of the same type, i have marked them in pairs and only run them in parallel, so there's less chance of mixing a discharged battery, with a charged one.
    I have also bought a couple of LiPo Voltmeters so I easily can check the state of my batteries.
  2. #42
    Mar 2013
    47
    so i should contact the seller and report that the 3s battery that was basically a 2s should have been tossed
    i have an online business on ebay so i dont want to be the type of buyer that complains even if its their own fault for not using something properly lol
    this is definitely some interesting stuff though, i hope they sell NEW lipos with huge warning labels on them too
    at least now i will get some repair experience when i fix the wires, just got to order the new chassis
  3. #43
    so cal
    9,244
    Don't worry about it then. Just buy a new chassis(dye it black while your at it)and read up on lipo care and get a quality lipo charger
    I wouldn't bother leaving him feedback either
  4. #44
    Mar 2013
    WV, USA
    129
    Quote Originally Posted by xboxhaxorz View Post
    This is was in the description.
    -SPC LiPO 2s 7.4V 50c 2500 MAH (2) run these batteries in parallel with the included adapter for near an hour of straight runtime.
    -Duratrax ONYX 3s 11.1V 25c 1300 MAH (2) one pack is slightly puffed due to one of the three cells being completely drained. The pack still works
    perfectly fine as a 2s pack. I have used this pack more than any of the others and it works flawlessly
    He basically told you to run the the 2 2s SPC in parallel. He also told you one of the Duratrax 3s lipos was damaged but it was still usable as a 2s lipo. With that said it doesn't appear that the partially fuctional Duratrax lipo was labeled by the seller as damaged or 2s.
    IMHO if it was my lipo I would have opened the pack, disposed of the damaged cell, rewired the pack and made it into a 2s pack. I would never sale a partially functioning pack to anyone for safety reasons.
    As far as who's fault it is well that's a bit more complicated. He did tell you there was a 3s pack that only worked as a 2s pack. It wasn't labeled or made into a 2s pack. He probably thought he was doing you a favor by including the pack. You also have very little experience with lipos and didn't check the packs when they arrived. Most of the time people on forums tell you that you need lipos and they are great yet they don't bother to tell you how to use them safely.
    It's really up to you what to do. At a minimum I would contact the seller and tell him what you did and what happened. I would also tell him that it's not a good idea to sell used damaged lipos that are not properly labeled.
  5. #45
    Mar 2013
    47
    long delay but i finally got a chance to work on it after we moved to a new location, i was going to solder the servo wires back to it but i found 2 2080s in the box so i just replaced it
    i bought a lip battery charger and got 2 connector for the traxxas style, which i took the 2nd to cut and soldered to the esc i was having trouble with the motor and trying to figure out where this piece goes
    http://traxxas.com/sites/default/fil...gear-cover.jpg
    its the long piece on the top right, i couldnt find any images showing how it is installed so i temporarily connected the motor anyways and tested
    initially i had no light on the esc so i disconnected the servo wire and that fixed it
    i re positioned the servo and got it to work and the motor worked just fine
    however when i was adjusting the steering nothing would happen so i assume its the position that is an issue
    so at least nothing MAJOR was damaged aside from the esc LOOKING burnt it works
    after i get this servo thing fixed and try it with the lips i will move on to investing into a new chassis, hook up both 2080 servos and probably hook up a small pc fan to keep things cool
    thanks for the help and now i know lips are quite dangerous
  6. #46
    Mar 2013
    WV, USA
    129
    If it is the black plastic cylinder piece it goes in the motor plate shown in the middle right of this pic I took.
  7. #47
    15,986
    Any energy-dense apparatus is dangerous if not handled properly. Ever see a NiMH cell go pop? It's not pretty.
    Alt-248 on the number pad =
  8. #48
    red deer alberta
    597
    I agreed ksb.. Like a little bomb in your car if they go off while your running
    Sent from my SGH-T989D using Tapatalk 2
    summit and e-revo sv2 5700, BL p2ede
  9. #49
    Mar 2013
    47
    no its the cylindrical piece on the top right of the photo
  10. #50
    Mar 2013
    WV, USA
    129
    See the black screw in my picture. If you look closely it is screwed into the black cylindrical piece. The piece fits in the silver aluminum mount.
