Results 1 to 21 of 21
    Mar 2013
    10
    help, I have a problem in OptiDrive
    sorry guys, I do not speak English and so I'm using google translator
    My problem in this OptiDrive, he's at 70% front and 100% aft, can someone help me get it back to normal? already looked in the manual, but does not explain very well
    Feb 2013
    Parker, CO
    364
    The throttle/brake servo needs to be reversed using the transmitter.
    Revo LRP 30x
    EMBE 6s
    ERBE 6s
    Summit 4s
    Mar 2013
    10
    Quote Originally Posted by rock-rod View Post
    first thanks for replying, but I've reversed the servo at the transmitter but not worked, have to reverse the opti drive, and how do I do this??
    Uk... Peterborough
    470
    sorry not really to sure what the issue is. the translation is not great, have you tried resetting the opti drive and going through the setup again?
    Mar 2013
    10
    Quote Originally Posted by RevoDeano View Post
    from what I understand, if agent holding the button set of the OptiDrive, it will blink green 2 times and then it flashes red once that the Normal setting, but if it flashes 2 times as in my case he is unlike, as I to do it flashes 1 time only?
    Mar 2013
    10
    help help help
    Tanker 822
    9,677
    Based upon the video (which I don't understand what you are saying, sorry) it appears everything is working normally. Is the problem with the carb opening 70% in forward and 100% when the transmission is in reverse? If so, how do you know the throttle is opening up 70% forward and 100% reverse? Best way to check is to remove the air filter and verify that when in forward and reverse the carb opens all the way.
    Mar 2013
    10
    that's right 70 forward, aft and 100%, how to make original again?
    Mar 2013
    10
    help , help , help
    Mar 2013
    Australia, vic
    137
    Reset it drive reset transmitter
    Mar 2013
    Australia, vic
    137
    I mean, reset the optidrive and the transmitter
    Sent from my GT-I9300T using Tapatalk 2
    Mar 2013
    10
    Quote Originally Posted by Ozrevoguy View Post
    I already did that
    Mar 2013
    Australia, vic
    137
    Hold down your optidrive reset, pull throttle all the way back then release. Light on optidrive should blink green twice to confirm.
    Mar 2013
    Australia, vic
    137
    Also make sure your servo horn for your throttle is mounted on the engine side correctly.. It can go in 2 places, if it's on the wrong spot it will throw it out
    Mar 2013
    Australia, vic
    137
    I'm out
    Mar 2013
    10
    how to reset the optidrive ?
    Mar 2009
    1,873
    just get rid of the opti drive
    you know.. i never had a sig.. but i do now...
    Aug 2003
    210
    Quote Originally Posted by kgombe1 View Post
    That's the best advise you can get, install a FOC and enjoy a reliable tranny!
    May 2013
    16
    Push and hold reset button until it links green 2 times then let off the button..pull full throttle and hold it until light blinks three times..then let trigger go to neutral..after a few seconds both lights will come on indicating programming is complete..
    Speed cost money!
    How fast do you want to go ?
