Results 1 to 23 of 23
    20
    Help my merv won't stop making clicking noises!!
    Hey guys! I'm new to the mini revo.. I traded my rustler xl-5 for it anyways, I have a weird clicking noise from the drive shaft in the center when I roll my car on the ground and when I run it it make a loud sound as if the driveshaft is hitting something or teeth is missing in the gear? Ive checked the spur,pinion,and the drivetrain but no luck BUT the weird part is that when I take my skid plates off and my t-bone skidplate/bumper the noise goes away? U think my drive shaft is bent? Or is it the gears in the black box that connects the front/rear drive train that's making the noise????
    Fast car with a fast car = WIN
    Northeastern CT
    235
    are the diffs shimmed yet?
    Stampede 4x4 vxl w/ MMP/2400kv, Mini E-Revo
    20
    No stock I believe.. But how is it when I take the protective plates off the clicking stops.. But when I put everything back together it starts again??
    Aug 2012
    Toronto
    414
    When you take the skids off its Probally giving it a bit more space between the ring n pinion
    When the skids are on it makes the bulkhead halves join together a bit more to give you that clicking.
    Black box = bulkhead
    so cal
    9,244
    The skids help hold the bulkheads together and keep the gear mesh
    What do you do with it off. Spin it in the air?
    Probably a stripped diff but do you see any damage around the center driveshafts area?
    20
    So I guess it's the diff.. There wasnt any damage, just that noise comming for inside or around the bulkhead. When the skids were off I rolled it the same way on a flat surface no sound, but when i put back on it came back lol!
    So I guess to be safe I should shim the both front and back diffs and since I'm there do the cvd's..and drive shaft? I'm planning on goin from 2s to 3s eventually so might as well..
    Urrghhh so much work!(just watch YouTube vid on diffs/cvd)
    Delaware
    123
    How does it run? is this your first brushless motor?
    so cal
    9,244
    Pickup a few sets of associated 21141 shims. Not to bad once you did it a few times. Plus you get to know your car better!
    Mar 2013
    Denmark
    27
    Had almost the same problem with my MERV when i recieved it.
    Found out that it was the spur gear hitting the gear cover (7077R).
    After flexing it a bit by hand, the clicking noise was gone.
    Gold Coast, Australia
    392
    MUST SHIM !!
    absolute must before running a MERV
    Mar 2013
    Denmark
    27
    Quote Originally Posted by graham_h View Post
    MUST SHIM !!
    Well, there were no space for even one 0,1 mm. shim on my MERV when i got it, so "must shim" isn't exactly true.
    so cal
    9,244
    Only seen one that didn't need a shim but wont know til you try.
    And better to try then have another strip
    Feb 2013
    Auckland, NZ
    208
    i don't mean to thread-jack, just curious about the way people shim here. has anyone tried shimming the pinion as well? using kyosho 4x6mm shims
    20
    Thanks guys.. Ya first brushless system.. I'm doin the cvds and shim on saturday. I got everything except the shims.. What size do I need??
    Oct 2012
    Puttin out a fire
    575
    Get these (Team associated 21141 shims). I went through the exact same problem on mine when I got it a few months back. I shimed both diffs and been fine since. I roasted mine running 4s (2s paralelle) also cost me a servo. But that was my noob (at the time) mistake.
    http://www.amainhobbies.com/product_...-324x409x005-4
    E-REVO MMM - Stampede 4x4 6s/3s
    20
    @fireman How many shims did u put?
    Anyone have any tips or advice before I start?
    Delaware
    123
    I would take the motor out first, then give it a roll back and forth. Doing this will eliminate any noise from the motor, and you'll hear the diff gears much better.
    Also, have you checked to see if the skidplate screws are too long? going into the case and rubbing the diff?
    so cal
    9,244
    Jul 2012
    43
    Quote Originally Posted by firemanJBI View Post
    FYI 2x2s parallel is still just 2s...
    2x2s series is 4s.
    20
    And so this is what I did to solve the clicking noise in my merv.
    -team associated 21141 shims
    -traxxas steel CVDs
    -traxxas center steel driveshaft
    -hs-81 hitec servo
    -diff grease
    BEFORE
    Cvds installed
    Hitek servo next to stock
    Center drive shaft
    Pull apart and shim diffs
    Throw my tbone back on.. Luv it!
    AFTER
    Sideview
    Hope this helps!! Shoutout to the ppl who helped and replied!
    What a long day... But it was well worth it! No more clicking and runs way more smooth!!
    392
    Looks great
    Lets see some vids of it running
    Paved Paradise Florida
    121
    what kind of push rods / toe links are those?
    MERV - 3S 23/50
    20
    Quote Originally Posted by iDrive View Post
    Push rods r from GPM I think and recently I snapped one of the toe links.. I replaced the front with TRX alum. And it's way stronger!
