Results 1 to 14 of 14
Thread: servo
    Vassalboro Maine
    206
    Question servo
    i was going to put dual servos in my 1 16 summit and was wondering where you would get the second stock servo horn for it?
    17
    only way i got one was to buy the whole steering rebuild kit.
    i thought what the heck, i dont want all this for one little horn. but found out that those extra parts come in handy.
    the steering arm that connects the two servos is really weak. i would get it in aluminum. thats my plan soon.
    Edited for language abuse. If you see a starred out word in your post, you must edit it out to avoid earning warning points.
    Vassalboro Maine
    206
    when i put the dual servos in it seams like they would work against each other is that the truth if so how would you wire it so they would work with each other?
    Alma, MI
    12,283
    Plug both servos in channel 1... there are two channel 1's on Traxxas receivers.
    I also suggest adjustable linkage so you can adjust the fight (to the death) out of them.
    Vassalboro Maine
    206
    what do you mean by adjustable linkage?
    SE Texas
    1,178
    will plugging in 2 servos to the two channel one ports automatically reverse the operation of one of the servos so they will work correctly or is this something you have to do manually in the settings?
    "Dude,I almost had you"
    R.I.P Paul Walker
    Alma, MI
    12,283
    Why does one of them need to be reversed?
    Vassalboro Maine
    206
    because if not wont they work against each other?
    Alma, MI
    12,283
    No, they will not.
    Vassalboro Maine
    206
    i see now,i order the parts to night.
    thanks Jimmie
    62
    I ran two servos for a while and in the end one died.. I upgraded to a single hitec servo and it's so much better.. My advice is just go straight to a better servo and be done with it.
    171
    Quote Originally Posted by froggie22 View Post
    Which servo do you use?
    62
    I use a hitec HS 5085MG. Some others use a corona brand and bluebird. All 3 make good servos that are highly recommended. Have a look through some of the mini revo threads and I'm sure you will find the specific part numbers.
    171
    Thanks froggie!
