Results 1 to 10 of 10
    shoreline WA
    100
    New driveshafts? Broken driveshafts.... :thumbdown:
    Just got traxxas's steel driveshafts, man am I disappointed...
    First look
    Guess I found the weakest link...
    The carnage.. Not too bad
    I guess the question is, where can I find a pin to replace the atomized one?
    Thanks in advance
    -Ian
    Jul 2011
    yankees suck
    88
    try a tiny drill bit cut to length. then maybe a lil bit of thread lock or shoe goo or something to hold it in.
    was an o-ring holding it in?
    so cal
    9,245
    That's just a fluke. Have been running them for over a year up to and over 65mph with no problems
    The pin from a 7055 will work could get by with the right size drill bit
    Oct 2012
    Coleman AB
    109
    I had the same problem, gave out on second run... just the one broke and I put the plastic ones back in the front and kept the rears and they have held up great.
    Summit
    Slash
    merv x3
    savage flux xs
    Feb 2013
    Auckland, NZ
    208
    call traxxas support, from what i hear, they have excellent support in the US, maybe they can sort you out with what you need. its worth a shot
    Poconos
    303
    Quote Originally Posted by DrakeBahamut View Post
    I went through this a number of times, the pins seem to be the weak point. I got to the point where I've given up and switching back to the stock plastics. (currently only running the metals up front, but the next time I change the front diff, they are swapping back to stock)
    Feb 2013
    Auckland, NZ
    208
    if you are still interested in steel driveshafts, integy makes excellent center shafts (version 2).
    these are one of the few products that are solidly built by that company, i have had mine for more than a year, no issues with em. they also use a steel band to cover the pins rather than rubber, if there is a con, i would say that it is much heavier than the traxxas set.
    http://www.toysonics.com/integy-t350...shaft-set.html
    so cal
    9,245
    I still say its not that common occurrence. I have heard of a few but not that many
    shoreline WA
    100
    Yeah, thanks for the opinions guys. I think it may have been a fluke too, right now I'm looking for something to replace it. I'll just look for a finishing nail and sand the head and point off. See if I can't find one that fits
    446
    a nail wont last long, the metal is too soft. You need hardened steel, like a drill bit. needle bearing pin maybee fit?
