Results 1 to 16 of 16
    Austin Tx
    360
    Track Day Tommorow :)
    Hopefully this time I will be able to race the 2WD league. First time so I'm a bit nervous
    Currently running the 18T Pinion with 56T Spur. Then maybe switch out to the 12T
    What too lookout for ??
    SanDiego, CA
    996
    1 thing I learned about racing which you might know already but sometimes even people that know get in the zone while racing and forget, don't focus on beating and passing your opponents just drive smart and try your best to not make mistakes, I've noticed while racing that 1 little mistake can close a gap big time or even cause a pass up
    Austin Tx
    360
    Thats ( XRated) ill keep that in mind
    Lafayette,LA.
    693
    That's some good advice xrated. Good luck at the race JD?
    Sent from Oser world
    Michigan
    5,222
    Quote Originally Posted by XRated View Post
    Couldn't have said it better.
    Austin Tx
    360
    Quote Originally Posted by dirty don View Post
    Thanks DON
    Billy u think the 18T would be ok or should I switch out to the 12T ? This track has a lot of jumps
    Michigan
    5,222
    I would run a 12, 18-56 is like 28-86 in 48 pitch,this is just my opinion,but would you run 28-86 gears on a sct.
    And I'm guessing it's not an official race track,I don't think they let you run 2.8's if it is.
    Quote Originally Posted by JDenham View Post
    Grassie Ontario Canada
    3,136
    Actually 18-56 is like 25/90 in 48 pitch
    Michigan
    5,222
    No it's near exactly the same as 28-86.
    18-56=3.11,28-86=3.071.
    four hundred's difference,that's pretty close.
    25-90=3.6.
    http://www.robinsonracing.com/gearratio.html
    3,136
    three ten's difference,that's pretty close.
    25-90=3.6.
    Okay..
    But I would think there has to be a closer one..
    And I just guessed on the pinion by using previous knowledge I didn't really calculate anything
    Maybe 28/90
    Okay I used the rr chart..
    29/90 will work but it's pretty much thevsame as the gearing you listed billy
    So that kinda gives you two options JDenham..
    Austin Tx
    360
    Well I had a blast placed 6th place overall out of 8. The track had some good size jumps. It was a bit loose it some spots. Overall it was fun I stuck with the 18T pin the whole time. Everynow and then it would pull up. The motor run around 115-125 degs temp.
    The 2.8 BowTies held up pretty decent. They have a hobby store next to the track so I walked it to check it out and ended up walking out with these for the rear hahaha
    Ran into a issue tho. The dang 18T pinion kept poppin off the shaft. I tighten it down snugged so I dunno what's up with that :-/
    3,136
    Did you use any blue locktite on it?
    Austin Tx
    360
    Haven't tried that yet thanks dude
    Just a Lil track video I took
    http://youtu.be/Vlfcm8RMS-0
    SanDiego, CA
    996
    +1, metal on metal I've learned to use blue loctite, it's not necessary on all places but it'll prevent problems and it's not a problem to get off when you need to but definitely loctite your set scew on your pinion
    3,136
    Well do that and let it cure for at least 8hrs
    Austin Tx
    360
    Ok......
