Results 1 to 2 of 2
    63
    Range is extremely limited..
    It happened after I unplugged all the eletronics for the first time (for me)
    I put everything back and everything works, but now the range isn't even close to what it used to be..
    I used to be able to go down the block, now after maybe 50-70ish feet it stops responding
    Fresh energizer batteries in the 2.4Ghz radio
    Tried adjusting the antenna,
    When I bought the truck the antenna was like this, and stayed like this until about 20 minutes ago
    Now its like this.
    I shortened it on a recommendation from 50togo, and it doesn't seem to help or make the problem worse..
    ...do I need more antenna? less?
    63
    Could the issue be that the uninsulated part of the wires that are going into the motor are uninsulated and therefore interfering with the signal?
