Results 1 to 7 of 7
Thread: Drive Shaft
    Torrance CA
    153
    Drive Shaft
    Think I may have a bent drive shaft. If I take it out and roll it on the counter it seems to have a slight bow in it. It broke of the front of my center diff and now with the slipper it makes a loud nose when running.
    What issues have you seen from a bent drive shaft?
    Colorado Springs
    1,851
    I think the slipper is pushing on the rear gear creating the noise from the rear differential.
    Easy way to tell.....put the rear end together, mount it to the car, take off the inspection plate and see if you can wiggle the spur gear to the front and rear. if its too tight, its more than likely pushing too hard on the rear gear.
    you can either shim the rear ring gear in the housing or sand down your slipper pads to create the space needed.
    "Red"
    "Who wants a Rod that you cant Mod?!"
    Torrance CA
    153
    I did recently change the diff fluid in the truck. The rear diff had no grease in the case but, the front had a hand full. I did not add any when I put it back togeather. Guess this could be the nose too. What do you think? Still think shaft is bent a bit.
    23
    what type of grease is used in the diffs and where can i get it?asking because i want to pull mine apart and change.what weight etc should i use ...is this grease any diffrent from regular mechanic grease for my regular car i can by from my local auto parts store...
    Torrance CA
    153
    Inside the diff (not the case) I used Losi diff fluid. 5,000F, 5,000C, 3,000R. Inside the diff houseing to me it just looked like black mechanic grease. Dont' care for my set up and plan to change it again. Still need to have more pull from the front wheels. Plan is to change to 10,000F, 7,000C & 5,000R.
    23
    ok cool.im not noticing any issues but just trying to further my knowledge ..
    Torrance CA
    153
    i was not haveing an issue until I changed the fluid. it was my first time changing it so I may have missed a step or did something wrong. HA HA HA
