    4
    E-Revo with Titan 775 is recommended?
    Greetings I am from Venezuela, I have an e-revo uninstall 5603 and want to install a dual engine 775 engine that is used by the summit. It recomenblable who does?
    1,890
    I used a single 775 on my E-maxx - its a little slower than twin titans and I think single 775 has less torque than twin titans
    It may have been the gears I was using on the twin titan setup.
    If you use dual 775, you're going to need 4 batteries and 2 ESCs
    Minnesota
    1,306
    You should dual Titan 550's. Or VXL's with a parallel connector.
    ERBE
    Savage Flux XL
    Trail finder 2
    15,126
    The EVX-2 has been shown to run dual Dewalt (820) motors many times. Why would you need 2 ESCs and 4 batteries for dual 775 motors? The 775s have the same voltage range as the 550s, but they do draw more amps.
    It can be done but I'm not sure if two 775s will give the performance you desire.
    Alt-241 on the number pad =
    363
    If you use dual 775, you're going to need 4 batteries and 2 ESCs this in Not true i built an erevo using twin 775's and 1 evx2 and i only use 2 2s 8200 mah batteries.this thing hauls.i have it set up with 22 pinions and 58 spur and i have not checked temps but it has never felt to hot to the touch
    4
    if I put a single motor which should place dewalt, Dewal product that I can find?
