Results 1 to 10 of 10
    187
    Mamba monster ESC cable direction and it's beeping
    Hello.
    I have a E-revo Brushless.
    I also got the Castlelink. There where no knob on the ESC cable connector from the mamba monster.
    Is this the right way?
    Also the car beeps... but first i want to know if the cable was the right or wrong way.
    la porte
    618
    It's supposed to beep
    6S OR NOTHING............................ maybe 5s
    Apr 2009
    380
    Brown is the negative side so you want it to be on the same side as the black wire. The ESC will beep when it arms and does a cell count.
    It appears your picture is backwards.
    187
    Yea, i know it should beep, but not all the time, not stopping once.
    But it works fine now.
    la porte
    618
    Oh ok ya a constant beep is no good
    Australia
    3,255
    Use your castle link and restore factory default settings...see if that helps. If you make any changes with the castle link remember to hit update in the bottom right hand corner of the software programme.
    Edit: just read post #4...is it sorted?
    Rock n Rolla !
    so cal
    9,244
    Didn't you say it works fine now?
    kansas
    7,811
    can't really tell from the pic but it looks like the ESC plug is backwards (pretty sure looking at the pic again). you have the brown wire in, not out. the servo wires are correct, they will only plug in one direction....
    all dark colors go out (meaning outer edge of the Rx) ie black, brown.....etc
    http://traxxas.com/forums/showthread...=1#post5406604
    Refer to this to setup the Mamba Monster ( MMM ) esc for maximum performance:
    CASTLE LINK GUIDE
    also you will need to set the throttle, break, & neutral set point every time you make an adjustment to the ESC...with CL...
    http://traxxas.com/forums/showthread...=1#post5400474
    RC Turnbuckle Jr. vxlrocket's Avatar
    Dec 2007
    Manassas, Va
    6,650
    CASTLE LINK GUIDE
    it is in backwards. +1 good catch. i always think to myself "light wires to the left" to remind myself
    Associated rc8TE, rc8.2E, B4.2, Ofna LX2E, Slash
    187
    Yes, it works fine now. Cable was wrong.
    Just wanted to have the cable right way before i start troubleshooting.
    I also calibrated the throttle, that did the trick i think.
