Results 1 to 10 of 10
    springfield,mo
    64
    Question Please watch and answer my question
    Hey guys I just got this new 3.3 broke in and took it out to the skate park here in town. My daughter recorded it so might be a bit shaky.
    My question is-"Is it just me or is My idle a pinch to high?"
    Here is the Vid-http://www.youtube.com/watch?v=wmwFP4nxZSw&feature
    Sep 2006
    West Virginia
    478
    Sounds ok to me as far as I can tell.
    1,890
    yes, its a bit too high. I am guessing the low side is too lean....have you pinch tested to stall the engine?
    One of the hardcore nitro guys should chime in soon - stay tuned
    Dec 2009
    texas
    271
    Sounds high to me.
    Bswift
    FASTEST "recorded/proven" JATO'S-3.3 AND Big block
    springfield,mo
    64
    yeah did the pinch test and was about 3 to 4 secs and it would die
    1,890
    if you let it sit for a 8-10 seconds, will the idle go down? are you using the servo to adjust the throttle or is there play in the throttle linkage?
    springfield,mo
    64
    yes if I let it sit it will go down a little. There is no play between the servo horn and the throttle pull, should there be??
    Jan 2008
    Sugar Hill Ga.
    8,340
    Idle too high.
    Idle gap too big and/or tuned too lean.
    You can’t rely on the pinch test; it will only get you in the ballpark. You should also do the pinch test immediately after a high speed run.
    You should have slight gap for throttle linkage.
    springfield,mo
    64
    Thanks for the advice.
    I put a hair width gap in the throttle linkage. I will get it up and running tomorrow and get some high speed passes thru it and do a couple pinch tests.
    New Orleans LA.
    11
    sounded a lil high but all engines are differnt fating it up a lil bit maybe just a thought as long as its where u want it an u dont over heat how u have it should be fine
