    Feb 2013
    California
    56
    One front wheel spinning faster than the other.
    Maybe you guys can help me out here. I've got one front wheel spinning faster than the other. Ones will freely spin for over a minute and the other for maybe 20 seconds. I've replaced all front bearings and the hub carries have also been replaced. Tried switching the axles around too but it stated the same. What could it be?
    Brooklyn Park, MN
    1,155
    1. The bearings may not be broken in
    2. The hubs may be rubbing on the bearing.
    3. You may have tightened the wheel nut too much.
    CM10 Samsung Epic - Tapatalk 2
    MM|2200kv 2WD LCG Slash - MM2|2650kv LCG Slash 4x4
    Nashville, TN
    1,876
    My vote is on #3, especially if you're using rpm steering blocks.
    Feb 2013
    California
    56
    How do I break in bearings? and on #3 this is even without a wheel on. Just spinning the axle by itself.
    397
    If its a 4x4 you might want to ask this in the 4x4 forum 2 forums down.
    Brooklyn Park, MN
    1,155
    To Break in bearings, just run your truck.
    The nut only needs to be slightly tight.
    The hub has a little overgrowth to it which might rub on the bearing and cause excess drag. I used a dremel on mine.
    Michigan
    5,314
    As stated above,if the hex pins is bent, the hex it self is wore from over tightening,or the axle shaft itself is bent ever so slightly.
    All of these can cause your issue.
    I changed to aluminum hex wheel mount's,and never had the problem again.
    And you break in the bearings by using it.
    [IMG][/IMG]
    South of St Louis
    6,062
    It's maddening trying to figure that out. I've had the same problem over the years.
    It could be the bearing carrier is warped. What brand do you have?
    Feb 2013
    California
    56
    Quote Originally Posted by Abyss View Post
    Its 2wd... which is why I posted here...
    One day old RPM.
    Im running STRC aluminum hexes and all the pins are straight as well
