Results 1 to 15 of 15
    196
    Spur best place to buy low teeth spur
    To run with a 31 or 33 pinion
    29
    Robinson Racing? You try them yet?
    196
    No i think it will be way to fast and ill destroy like a wise friend told me i will probably use them tho
    Lansing, Mi
    333
    How low r u thinking
    My wife hates it but I love It.
    196
    I was thinking a 49.... And 31
    196
    I mean a 59 and 31
    Grassie Ontario Canada
    3,136
    Idk..
    Try a 83t
    It works fine
    Lansing, Mi
    333
    well divide the number of teeth by the pitch 59/48 = 1.2" dia. That wont fit over the slipper cage.
    69 is going to be the smallest and i think u need to update to the associated slipper setup to do it.
    I think the smallest one you can use with the stock slipper is 76
    3,136
    Yeah 76 is the smallest.. But 83 I think will get you a better mesh...
    @wormer in the Netherlands
    299
    @ razorback fan
    what gears you use?
    *stock 48p (slash 2wd)
    *32p / m0.8 (slash 4x4)
    *m1 (Revo)
    wich motor/esc combo ?
    bashing or speedrun?
    sand, gravel, pavement...
    for me i prever the m0.8 spur / 32p pinion combo
    spur size 54t, 56, 58t
    pinion size 11t, 12t, 13t, 14t, 15t, 16t, 17t
    58 / 17 gives lots of speed but it`s hard on the LiPo`s so short runtime
    56 / 14 or 54 / 14 is a good average setup to start
    if you bash in loose sanddunes combined with sandpaddles
    gear down 54 / 12
    franz
    greetings from holland
    www.rcm-alkmaar.nl
    3,136
    Quote Originally Posted by franzD1 View Post
    @ razorback fan
    what gears you use?
    *m1 (Revo)
    gear down 54 / 12
    I'm 99% sure he's using 48 pitch..
    He said 33 tooth pinion..
    299
    i think so, but he gave so little information
    from other post of him i found he got a VXL
    but i used this text before @ other forum, so just Ctrl C > Ctrl V here ;-)
    franz
    www.rcm-alkmaar.nl
    196
    I run on pavement 48 pitch 3s lipo 6400 mah vxl system and speed run
    299
    from the slash manual
    franz
    www.rcm-alkmaar.nl
    299
    so theoretically 76 / 31 could work
    up to 84mph or 123.62 mph by highly unstable balooning tires
    Differential Ratio: 1
    Transmission Ratio: 2.727272727272727
    Other Ratio: 1
    Spur Tooth Count: 76
    Pinion Tooth Count: 31
    Total Voltage: 12.60
    Motor KV: 3500
    Tire Diameter (inches): 4.3
    Tire Ballooning (inches):
    Spur/Pinion Ratio: 2.45 : 1
    Total Ratio: 6.68622 : 1
    Tire Circumference (inches): 13.51 inches (343.12 mm)
    Rollout: 2.02:1
    Total Motor Speed: 44100 RPM
    Vehicle Speed: 84.37 mph (135.53 km/h)
    Effective KV Value: 3500
    so thats theoretically
    in real life top speed should be 10 a 15% less because of drag, resistance...
    franz
    www.rcm-alkmaar.nl
