This is another drag racing question and I have found with foam tires that its very easy to strip gears if the slipper isn't loosened quite a bit. My question is can you allow it to slip too much if your running a high revving top end motor? Would a slipper loosened to the maximum allow you to get the car down the track into those high rpms before it locked?
