Results 1 to 16 of 16
Thread: It's Alive!!!
    SE Texas
    1,178
    It's Alive!!!
    Well...after a couple weeks living in a freezer bag in a zillion pieces...the Summit is finally back together.
    The diffs are both now shimmed,the twisted rear center shaft(and the front one) have been replaced with the steel Traxxas shafts,and the long travel rockers were ditched in favor of a set of blue aluminum Revo rockers.
    I also replaced both bumpers...and installed a Axial light kit.
    While I was at it...I removed the rear bumper mount and replaced it with a Revo wing mount.(had to notch the rear of the body to make it fit.)
    The reason for this was because when you put a wheelie bar on the back of a Summit using the factory bumper mounts...it flexes really bad.By replacing them with the wing mount..it makes it really rigid and a lot more effective.
    "Dude,I almost had you"
    R.I.P Paul Walker
    Indiana
    733
    Nice job dc looks great...I so need to get a light kit
    Let's Go Steelers!!!... KCCO
    Baton Rouge, LA
    1,066
    Any pics of the rear mounts?
    / 16
    SE Texas
    1,178
    I can take one...give me a few minutes
    If it wouldn't be so heavy...I thought about making it into a spare tire holder.
    R.I.P Paul Walker
    Baton Rouge, LA
    1,066
    Is it worth swapping the rockers?
    / 16
    SE Texas
    1,178
    I am pretty sure it makes axles last longer due to the reduced angle of the joint.
    R.I.P Paul Walker
    Baton Rouge, LA
    1,066
    Did you lose a lot of travel?
    / 16
    SE Texas
    1,178
    It doesn't seem like it.
    R.I.P Paul Walker
    Indiana
    733
    dc if I switch the LT rockers for the PT rockers do I have to change anything else with them, I dont do I?
    SE Texas
    1,178
    not a thing...just the rockers.
    R.I.P Paul Walker
    Feb 2013
    32
    if I understand correctly you should be able to run the Traxxas steel driveshafts now that the LT rockers have been removed...?
    SE Texas
    1,178
    Probably so...but not 100% sure on the rear since it still has the extended rear arms on it.
    R.I.P Paul Walker
    Earth
    429
    Quote Originally Posted by dcfox View Post
    Nice Job they look good! Question with the Merv anodized wheels where they a direct bolt on or do you have to do something else to get the on. Thxs
    SE Texas
    1,178
    Direct bolt on.They are really close to rubbing on the inside but they fit.
    I'll eventually be getting another set for the Summit.
    R.I.P Paul Walker
    Earth
    429
    K thanks i will be ordering a set!
    SE Texas
    1,178
    Here's a quick pic of the wheelie bar showing how close they are(but they do clear)...
    You could always add a couple thin washers on each side to give a little more clearance.
    R.I.P Paul Walker
