Results 1 to 25 of 25
Thread: Waterproof?
    196
    Waterproof?
    I had a a traxxas slash with the vxl system big bores etc i ran in two kinda of a deep ditch will it be ok till the water goes down and no i did not have a ballon over the battery
    79
    I know you don't wanna hear this, but its probably gonna seize every bearing in the truck. That's not to say you should go in after it though. Your well being is much, much more important than that truck.
    Sent from my DROID4 using Tapatalk 2
    Concrete does not digest well...
    196
    I have 800 already invested in it
    So my feelings are hurt, bearings can be replaced cheaply but car cant
    79
    Just make sure you dry it out real well and go through it be for you run it. The battery is probably toast. Motor bearings and sleeves probably toast too by the time you get it out.
    196
    What all should i go-ahead and buy?
    And what do you mean by sleaves
    I found it no bearings were seized and lipo was fine
    79
    They will seize...wd40 the crap out of them to displace the water. I would not trust that lipo!
    196
    Do u think the lipo will blow?
    190
    when my son runs his Summit in flotation mode, I pull the four corner bearings and put them in a Ziploc bag that I partially flood with a WD40 like product. The summit bearings have never failed me. I just lay the bag flat on its side with the bearings all flat on their side and let it soak overnight. That way any moisture is subjected to the product and the bearings are not going to be run dry or with rust.
    Sent from a Galaxy S3, far....far away.
    196
    Ok thanks i will have to do it tomorrow after school should the motor b ok?
    79
    If water got under the shrink wrap it will start to corrode.
    196
    Is the vxl sealed and do you think the lipo be ok?
    Brooklyn Park, MN
    986
    I'd say the lipo would be fine as long as it isn't the slightest bit puffy.
    I'd go through everything and lube things, mainly tear into your transmission, motor and wheel bearings.
    MM|2200kv 2WD LCG Slash - MM2|2650kv LCG Slash 4x4
    196
    Dont wont to have to mess with motor...... Or tranny unless i have to
    Brooklyn Park, MN
    986
    Well, you should. It isn't that hard to do and it will prevent bad bearings and such.
    South of St Louis
    5,986
    You'll need to open the transmission case and all the bearings and gears, open the diff too and let it all dry out for a few days.
    Remove all the wheel bearings and let them dry out.
    Remove the motor end cap and the clear piece of tape and see if any water runs out. Actually, you should probably remove the long motor screws and open the motor to dry out for a couple days.
    Open the receiver box and let it dry out too. These trucks are supposed to be waterproof, but I'd say they're more water resistant, especially when submerged for a few days. If you have an aftermarket steering system I'd also remove those bearings.
    I'd like to know if water got in the receiver box. And post some PICS!!! (we like to see carnage)
    196
    Whats funny is it all still works just bearings a few seized up and i guess lll open up the tranny and do what yall said when i get home would it hurt if i sprayed the gear box out with airhouse then put some 3 in 1 on and ill take the motor the motor screws out and see if water got in it if it did ill take it apart and look it over ill soak them in wd-40 for a while
    Michigan
    4,977
    I go thru my transmissions every week during racing season,just to replace the diff axle out put bearings,and clean and inspect everything.
    It would be a wise thing to do imo.
    As mentioned above,if you don't,it will just be worse in the long run.
    And would,as stated above,open the motor,for the time spent,you could save a lot of headaches and $
    Quote Originally Posted by razorback fan View Post
    404
    Ithought it was waterproof too so i didnt dry the motor, now the bearing on the motor is rusted and i have to replace it, what sucks is one of the screws on the motor was stripped. Lol so now i dry everything after a wet run.
    Grassie Ontario Canada
    3,136
    Quote Originally Posted by Cobiispo View Post
    I've done that before
    Not fun..
    404
    Quote Originally Posted by kdvanb View Post
    Not fun..
    why does that screw have to be sooo small /:
    Edited for language abuse. If you see a starred out word in your post, you must edit it out.
    196
    How did you get the screw out?
    404
    I didnt yet, i heard that i should use a dremel to cut like a line straight across so i can use a normal flathead to screw it out, hope it works
    Brooklyn Park, MN
    986
    That or pliers if you can get a grip on it.
    CM10 Samsung Epic - Tapatalk 2
    319
    I know this isnt going to make you feel better but my big bro drove a brand new rustler vxl into the ocean at night on its first drive and a fatty wave took it away. I will never let him live that down. I stripped to my underwear and was in that water so fast but was not so lucky....
    What im saying is I feel your pain...
    3,136
    Well..
    I kinda used a drill..
    Wrecked the screw and motor casing..
    Still works just only has 1 less screw holding the casing...
    Don't do what I did
