Thread: Storage Mode?
    Sep 2012
    61
    Storage Mode?
    So i am using a traxxas ez peak plus charger and i want to use storage mode to store it. This charger only allows you to charge discharge at a maximum of 2.0 amps in storage mode. I am using a 7.4v 5000Mah lipo battery. What should i set the amps at for this mode? Is 2 amps to much?
    If i were to take a guess i think i would set it at 2 amps.
    Oct 2011
    new york state
    724
    Yes I would reccomend 2 amps if it is the lowest you can go
    You ain't bashin unless your crashin!!
    Sep 2012
    61
    i can charge/discharge at .1 amps is minimum it will allow? Do you mean highest? .1-2.0 amps is the range it allows on storage mode.
    Oct 2011
    new york state
    724
    I'd say just go with one amp to be safe....1 amps would take a long time
    Sep 2012
    61
    I guess im just a litle confused about why such a low amperage? If i run my battery to 3.6v per cell can i use storage mode a 2 amps and be ok? Then if i run my battery say only to 4.1v per cell and need to discharge then ill use 1 amp for storage mode since im discharging
    1,789
    I'd set it for 2A on any voltage, Your only limited by the charger's power.
    Guide books aren't part of the packaging.
    Oct 2011
    new york state
    724
    Quote Originally Posted by bazookal07 View Post
    Yes you should be fine there...I was only saying a low voltage of 1 amp just to be safe
