    SanDiego, CA
    996
    Antenna question
    Can I cut my antenna to be short in my slash so it doesn't have to stick out the body
    Mar 2013
    Fresno, California
    24
    I dont think so because my antenna snaped and it would barley got 20 before it lost connection
    South of St Louis
    5,986
    Depends if it's an AM radio (yes but reception will suffer), or the newer 2.4ghz radio (no). Either way I would just run the length of wire along the chassis then out the top. Cutting to length is bad.
    SanDiego, CA
    996
    Yea mines a 2.4hz
    Mar 2013
    Fresno, California
    24
    I belive so I burnt the box I got that Ram model one
    Feb 2013
    23
    http://traxxas.com/forums/showthread...tennae-in-body
    Same question couple days ago...works just fine for me..not cutting just tucking under the body.works good.only lost about 20 feet of range.
    Michigan
    5,205
    NEVER cut your antenna,2.4 put it in the body or something ,but don't cut it,I don't know why,but some are longer then others in the 2.4's,but I do know cutting is a no no.
    Quote Originally Posted by XRated View Post
    Jan 2008
    South Jersey
    8,237
    Years ago when AM receiver antennas were 20 feet long (that may be a little exaggerated, but not much ) we would run the antenna through the straw, then wrap the remaining wire around the outside of the antenna tube. That way you don't have to alter the wire, but can still keep in sorta contained.
    Long Beach, California
    6,578
    2.4ghz antenna can be as short as 2 or 3" long with the antenna tube but, never to cut the wire itself. my 2.4 wire was damage before to a point that i only get 10 ft away then looses its signal. one night seating inside my garage looking at the broken wire......got this idea.....what if i cut some of the black skin about the same length of the actual wire tip.....work wonders for me, got the signal back.
    | Rally GT8 Powered By CC | BackSl4sh Roadrunner |
