Thread: temp sensor
    Sep 2012
    86
    temp sensor
    who can tell me a little about it? i want to put one one my revo 3.3. already have the ipod and tqi, why not make it worth having. where/how does it mount? does it wrap around the motor? is accurate? is it worth having? thanks
    Jan 2008
    Sugar Hill Ga.
    8,382
    Volt/Temp sensor. Temp loop attaches around the base fin of the cooling head. The grey plug inserts in the V/T slot in the receiver, the red into any open channel.
    I’ve compared the temp loop with several IR guns and as long as it stays snug around the cooling head, it was within a few degrees of the IR guns. If the loop becomes loose fitting you will get anomalous readings.
    The temp loop can also be removed from the sensor harness and the Volt reading will still function if you like things less cluttered and prefer an IR temp gun.
    If you get if for the Revo, get the long temp loop.
    Lompoc, California
    51
    I use the tqi system with my iPod touch and I love it i set up mines so it shows temp and voltage..
