Results 1 to 8 of 8
Thread: Prop
    68
    Prop
    What prop should i use on 6s and 4s and im also looking to get a different flex shaft?
    Montreal, Canada
    539
    On 4S the stock plastic is still fine, for 6S Octura X442 or Prather 215 those props. are close to the stock prop. Flex shaft try Jeffwholts, if you run more on 6S upgrade to a .187 flex cable.
    68
    Do i need to change the brass tubing or stuffing tube for a .187?
    Jun 2011
    369
    I brought my previous post forward to show you how to install a larger brass tube with teflon liner to run a .187 flex cable. Or you can run the .187 flex cable in the stock tube without the liner. I prefer the teflon liner.
    68
    Do i need a bigger coupler?
    Montreal, Canada
    539
    Yes you will need an Octura Coupler or similar. It's up to you if you want to upgrade on the brass tube with a liner or use the stock one without any Teflon liner.
    Here is a comparison
    Right is the stock .150
    Left is a .187 flex cable
    This is an exact fit when you use the stock brass tube
    68
    What size coupler?
    Montreal, Canada
    539
    I'll PM you the link. It's a .187 coupler for nitro boats.
