Thread: MIP CVDs
    San Jose
    171
    MIP CVDs
    MY MIP CVDs have quite a bit of contact with my STRC steering blocks, I really do not want to remove material from my steering blocks. Just wondering if any of you running this set up?
    Thanks,
    DJ
    Rustler,Slash 4X4, 1/10 Rally
    Aug 2007
    NorCal
    112
    My Stock Traxxas Aluminum ones needed a little touch up with the dremel. Very little. Its just the MIP Axles are so big in that area, or you could limit your travel. But they dont need much.
    Rally, Slash 4X4, Summit 1/16
    7,172
    A few people will let them rub the contact area until smooth. On my Pede 4x4 with MIP's I used the sanding wheel from my dremel and ground enough off so there would be no contact. Then took fine grit sandpaper and made it baby bottom smooth. I like this much better. About 5 minutes work on each side and they were good to go.
    Weak Revenge
    Strong Forgive
    Intelligent Ignore
    7,172
    Here is a pick of the carrier. I ground a little meat off the inside where it rubbed. I can't find the pic I took afterwards. ugh
    Weak Revenge
    Strong Forgive
    Intelligent Ignore
    San Jose
    171
    Mine are locked up and don't even move when straight, so I was going to throw them on my slash and see how much I needed to trim off the factory parts so I could measure.
    Thanks for the replies
    DJ
