    Feb 2013
    In my room with this internet machine
    93
    Can you reverse the steering in this?
    I just got a nice Traxxas TQ transmitter and reciever, and I was wondering if it is possible to reverse the steering since I'm used to it being the other way around. It was this to be exact http://www.ebay.com/itm/Traxxas-TQ-2...item20ce924bed Any help is much appreciated.
    15,916
    Steering reversing procedure:
    1. Press and hold the SET button on the transmitter for two
    seconds. The status LED will flash green.
    2. Turn and hold the steering wheel to the full left or full right
    position (it does not matter which position you choose).
    3. While holding the steering wheel in position, press the SET
    button to reverse the channel.
    4. The channel is now reversed. Confirm correct servo operation
    before running your model.
    Throttle reversing procedure:
    2. Move and hold the throttle trigger to the full forward or full
    brake position.
    3. While holding the throttle trigger in position, press the SET
    Warning: Changing the direction of the throttle servo will also
    change its neutral position. Be certain to confirm the throttle servo
    properly closes the engine’s throttle opening when the transmitter’s
    trigger is at neutral.
    Alt-248 on the number pad = °
    Feb 2013
    93
    Thanks that was really helpful.Now I can drive comfortably again
