Page 6 of 11 FirstFirst ... 45678 ... LastLast
Results 201 to 240 of 401
  1. #201
    so cal
    9,244
    Clamp style will probably work fine.
    Those might work. If you have a dremel you could cut a groove in it for a flat head
  2. #202
    Minnesota
    1,306
    We have one in the garage but I don't trust myself with it. :P
    ERBE
    Savage Flux XL
    Trail finder 2
  3. #203
    Minnesota
    1,306
    This will work with my servo too right? http://www.amainhobbies.com/product_...rvo-Horn-Black I like how it has two screws to hold the clamp..
    ERBE
    Savage Flux XL
    Trail finder 2
  4. #204
    Jun 2010
    Miami, Fl
    6,731
    Yeah that would work, you can get it a bit cheaper on ebay.
  5. #205
    kansas
    7,820
  6. #206
    Minnesota
    1,306
    So I ran the truck today everything is good except my spur is missing a tooth good thing I'm switching to my 54 tooth spur. One question how do I get the spur off if it's in the cutout? Also anyone run 18/54 before? Better than 18/65 right?
    ERBE
    Savage Flux XL
    Trail finder 2
  7. #207
    kansas
    7,820
    unmesh the motor or take it clear off, then take the three screws out of the spur. Slide the spur off, might be easier to slide the bearing out of the spur to get spur off..
    http://traxxas.com/forums/showthread...=1#post5105092
    18/54 & 2/2s is a good start for gearing.....
  8. #208
    Minnesota
    1,306
    Well wonderful, I hate motor mount screws. I had a stripped one on my slash now here..........
    ERBE
    Savage Flux XL
    Trail finder 2
  9. #209
    so cal
    9,244
    Only way to do it. Its a pain but what are you going to do!
    You could go taller on the gearing but should run cool
  10. #210
    Minnesota
    1,306
    Well I got the spur off but I was gonna adjust the motor on the motor mount so the wires don't hit the ESC, got one screw out and the other screw is stripped. I'm like a raging ball of fire right now. Stripped screws are really getting to me..
    ERBE
    Savage Flux XL
    Trail finder 2
  11. #211
    la porte
    623
    Quote Originally Posted by Fr8cture View Post
    Youch 18/65 on 4s must be slow as molasses lol I thought 18/54 was slow.. But ya 18/54 is fine on 4s I'm gonna do 20/54 I have lst2 diffs which is good for about 2 teeth pinion
    6S OR NOTHING............................ maybe 5s
  12. #212
    so cal
    9,244
    Losi diffs is more like 4 teeth
    Punch it into the speed calculator and use losi diff instead of revo
    Which screw did you strip?
  13. #213
    la porte
    623
    I would suggest a good set or hex tools they will save a lot of stripped screws and sore hands I use dynamite tools but there are many brands to choose from
  14. #214
    Jul 2012
    Saint Louis, MO
    504
    I am running 21/54 right now and after a good bash have yet to see motor temps above 101F. Grant it it is only 55F here now. I hit mid 40s with that gearing.
  15. #215
    Minnesota
    1,306
    One of the screws that holds the motor onto the motor mount. I really would like not to dremel the screw and scratch the crap out of my motor mount. Already did that once...
    ERBE
    Savage Flux XL
    Trail finder 2
  16. #216
    la porte
    623
    Use a 1/8 drill bit and drill until the head of the screw pops off then unscrew the threaded portion with a pair of pliers just my 2 cents
  17. #217
    Minnesota
    1,306
    Sounds risky.
    Also is Stanley tools not good?
    ERBE
    Savage Flux XL
    Trail finder 2
  18. #218
    so cal
    9,244
    if it's the head of the screw get a set of these http://www.dynamiterc.com/Products/D...ProdID=DYN2904 they have a hardened tip
    i also use a these craftsman easy outs run it of a dewalt driver and pulls it right out
  19. #219
    la porte
    623
    That's the set I have and you can buy additional drivers for any size and its not risky safer that going to town with a dremel
  20. #220
    Minnesota
    1,306
    I guess I dont understand if I drill the screw and the head pops out do you mean the screw comes slightly unscrewed or the head brakes off the screw? Also looks like my LHS carries those drivers. I just got a dynamite servo arm from there today, too bad they are closed on Sundays. Monday it is then.
    ERBE
    Savage Flux XL
    Trail finder 2
  21. #221
    la porte
    623
    The head comes off leaving the threaded portion sticking out which you remove with pliers there's no tension on the screw anymore because the head isn't pressing against the plate anymore ...... If your not comfortable you could grind a flat grove in the head and use a flat head screw driver to unscrew it
  22. #222
    so cal
    9,244
    better to get an easy out any decent hardware store should have them
  23. #223
    la porte
    623
    Haha or that lol prolly gonna be your best bet
  24. #224
    kansas
    7,820
    if you ever have a tight screw that is Loctited.. put some heat to the screw.. solder iron or something, will help break loose the screw without stripping the head, & a good allen head too.....
    if you drill the head off the screw there should be a little left of the screw. then just take vise grips or pliers & screw the rest of the screw out.. after a little heat.....
  25. #225
    so cal
    9,244
    Get a set of tony's screws for your revo also. Best out there!
  26. #226
    Minnesota
    1,306
    I have no idea if it was loctited. I doubt it since the other screw was not loctited.
    ERBE
    Savage Flux XL
    Trail finder 2
  27. #227
    kansas
    7,820
    stuck screws Loctite or rusted....heat will help break loose stuck bolts & screws...
    larger bolts you use a lot of heat & WD-40 to get them to break loose........
  28. #228
    so cal
    9,244
    Even a hair dryer might help!
    With good tools and good screws you won't have a problem
  29. #229
    Minnesota
    1,306
    I have a feeling its the screws...
    ERBE
    Savage Flux XL
    Trail finder 2
  30. #230
    California
    4,840
    better screws then is in order i know i want to get some those are on my wish list some tony's screws for both my emaxx and merv and whatever rc next i get. i had stripped screws and used brand new tools for them too that i just got and bam stripped mad me mad but i dermeled the screw head for a flat head and got it out still better screws are in order
    DEU 8:18 ESV
  31. #231
    Minnesota
    1,306
    I decided to keep it on the motor mount until I can get some new screws. Went and ran it today man does that make a change going from 65 to 54. Too bad my gear mash was too tight and my Spur is completely stripped. Guess I gotta get a new one tomorrow.
    ERBE
    Savage Flux XL
    Trail finder 2
  32. #232
    California
    4,840
    you know i ended up using other screws i had left over from my nitro's lol worked out fine too if i had the right size though which i used to mount my motor on
    DEU 8:18 ESV
  33. #233
    so cal
    9,244
    these are some of my spare screws!
  34. #234
    Minnesota
    1,306
    I got a bag of screws that came with my STRC LCG slash chassis that I've been using for random screws I loose. They seem to be of higher quality but not rust proof. I also just got my red shock bodies and red pushrods. They came yesterday I guess but nobody checked the mail. lol
    ERBE
    Savage Flux XL
    Trail finder 2
  35. #235
    Minnesota
    1,306
    Anyone know what body this is?
    ERBE
    Savage Flux XL
    Trail finder 2
  36. #236
    California
    4,840
    looks maybe like a platinum revo body?
    DEU 8:18 ESV
  37. #237
    Minnesota
    1,306
    Close but it doesn't have the top hoodscoop and on the sides the platinum doesn't have the indent.
    ERBE
    Savage Flux XL
    Trail finder 2
  38. #238
    California
    4,840
    humm i even looked at the proline slipstream and its not that either funny looks in between each of those. maybe someones custom body design? im at a lose right now on that.
    DEU 8:18 ESV
  39. #239
    Minnesota
    1,306
    Quote Originally Posted by mike-susieq1 View Post
    I know the guy customized it but thats just the wire mesh and leds.
    Also I'm about done with the hot racing rockers, waste of money.
    ERBE
    Savage Flux XL
    Trail finder 2
  40. #240
    Jul 2010
    Beautiful SoCal
    889
    I had a screw issue. The hobby shop didn't have a screw removal kit, and I didn't know they came small enough. He heated the part with a soldering iron to melt the locktite then dremeled the screw and used a flathead to remove it. There was some carnage, but the threads are still functional.
    Jesus, Lights, RC, Minecraft, LoL
