+ Reply to Thread
Page 2 of 11 FirstFirst 1 2 3 4 ... LastLast
Results 41 to 80 of 401
  1. #41
    Minnesota
    1,300
    So I went out today and I didn't have much room to open it up but I saw smoke coming from the slipper area and could smell burning plastic. What could be the problem? Slipper to tight?
    ERBE
    30th Grave Digger
    Slash 4x4
    MGT 8.0
  2. #42
    The Netherlands
    504
    Too loose! A loose slipper is a lot of slipping = friction, causes to heat the clutch and melt spur gear = burning plastic
  3. #43
    Minnesota
    1,300
    Okay thanks will tighten it.
    ERBE
    30th Grave Digger
    Slash 4x4
    MGT 8.0
  4. #44
    13,578
    You may want to remove the gear cover to inspect the spur gear for wobble.
    I know they're having their break there by your brake drums. No, you're not invited.
  5. #45
    Minnesota
    1,300
    Just went out again with it tightened, didn't tighten the motor enough so re tightened it and everything is good. This thing has insane power. When the slipper was loose I was disappointed in power but once tightened it is insane! Very happy with this purchase.
    ERBE
    30th Grave Digger
    Slash 4x4
    MGT 8.0
  6. #46
    The Netherlands
    504
    Hehe, i had exactly the same when i first drove the revo. Hmm, thats it? Ok ok, only 4S, but thats it? Then i read the manual and read about breaking in the clutch and tightening it after breaking in. Then the true power was released . + 18/54 instead of 18/65 for some more top speed, and since we have more than enough torque, still more than enough acceleration.
  7. #47
    Minnesota
    1,300
    Truly is a 2wd truck on pavement. lol
    ERBE
    30th Grave Digger
    Slash 4x4
    MGT 8.0
  8. #48
    kansas
    6,402
    slipper break in kind of important.. might flip the pads over & the clutch plate, & try to break in the pads......
    Slipper Clutch Break In
    Post #283
    http://traxxas.com/forums/showthread...=1#post5388463
  9. #49
    so cal
    9,245
    Would be better to buy new pads. They are tapered and are supposed to go in one way but probably wont hurt
  10. #50
    la porte
    552
    I don't use pads I use a tmaxx 2.5 brake disk it's a perfect fit and works a million times better I got lucky I had an extra from way back when the 2.5 was new lol
    6S OR NOTHING............................ maybe 5s
  11. #51
    Minnesota
    1,300
    Well just had the pin fall out of one of the CVD's. Is there somehwere that shows a diagram of mip cvd's?
    EDIT: if the grub screw is supposed to keep the pin in but is covered how do you lighten the grub screw??
    ERBE
    30th Grave Digger
    Slash 4x4
    MGT 8.0
  12. #52
    la porte
    552
    You can turn cvd so you can access the grub screw
  13. #53
    Minnesota
    1,300
    not for the grub screw im talking about.
    Part 4 here http://www.miponline.com/store/media...1101-page1.jpg
    ERBE
    30th Grave Digger
    Slash 4x4
    MGT 8.0
  14. #54
    la porte
    552
    Oh ok I figured they were like most Cvds hopefully someone else has them may know something
  15. #55
    Australia
    3,065
    Part #4 is a grub screw on that diagram...you need to bend the ball joint to get access to it to be able to fasten tight.
    Edit: if the CVD is already on the truck you wont get access to the grub screw on the diff output.
    Rock n Rolla !
  16. #56
    Minnesota
    1,300
    So I have to take the cvd off the truck? sigh..
    ERBE
    30th Grave Digger
    Slash 4x4
    MGT 8.0
  17. #57
    Australia
    3,065
    Unfortunately so mate...that's how we learn .
    Rock n Rolla !
  18. #58
    Minnesota
    1,300
    Nope, I didn't have to I just took off the lower a-arm and could bend it enough to see the grub screw sweet.
    ERBE
    30th Grave Digger
    Slash 4x4
    MGT 8.0
  19. #59
    Minnesota
    1,300
    Quote Originally Posted by Fr8cture View Post
    Okay so heres my list of my first changes to the truck.
    -Red Summit body (New graphics)
    -Summit light bar
    -Summit bumpers with lights
    -Summit body posts
    -Hot Racing silver Rockers front and rear
    Just ordered this stuff.
    ERBE
    30th Grave Digger
    Slash 4x4
    MGT 8.0
  20. #60
    so cal
    9,245
    That will keep you busy!
    Always like when some packages are do in and the have some wrenching to do!
  21. #61
    Minnesota
    1,300
    Yeah got some 500k diff oil and 80wt shock oil coming too.
    ERBE
    30th Grave Digger
    Slash 4x4
    MGT 8.0
  22. #62
    Minnesota
    1,300
    How exactly do you make a rear chassis brace? I was looking at tvr's Tor-X chassis brace but its $25 plus $15 shipping. I was gonna get it just for the plate. So how do you make a plate?
    ERBE
    30th Grave Digger
    Slash 4x4
    MGT 8.0
  23. #63
    The Netherlands
    504
    Get some aluminium or carbon fiber plate and cut a piece that goes over the shock tower with the 2 holes for the shock tower screws. Then for the tie rod drill one hole in the middle of the plate, and you're done . Other side of the tie-rod goes to the wing mount.
    Hm, wanted to go for the Tor-X myself too, in combination with a HPP motor mount, but 40 dollar is somewhat too much for just a tie-rod..
    By the way, thats your second option. Get a HPP motor mount, which is a great upgrade if i may believe everyone here, and drill and tap a hole in the center of the HPP shock tower mount .
  24. #64
    so cal
    9,245
    http://traxxas.com/forums/showthread...-e-revo/page13
    I.ran one with the hpp motor brace and tekno sway bar and traxxas toe link
  25. #65
    Minnesota
    1,300
    Forgot to mention I got the castle motor fan.
    ERBE
    30th Grave Digger
    Slash 4x4
    MGT 8.0
  26. #66
    Minnesota
    1,300
    IS there any good wheelie bar options with a single wheel? I have the stock wheelie bar but it looks so ugly and the integy one well you know its integy... Any other options? I saw someone made a brace to make the savage flux wheelie bar work but i'm not really up to doing that.
    ERBE
    30th Grave Digger
    Slash 4x4
    MGT 8.0
  27. #67
    RC Turnbuckle Jr. RC-Fan's Avatar
    Jun 2010
    Miami, Fl
    6,649
    I wouldn't get the mashers not because they are bad, because you already have the trenchers which are pretty good on any terrain, since you want the looks big joes on axial looks pretty awesome. I would consider a single high torque servo, and the shroud before getting the bling.
    FLM - EMAXX
  28. #68
    Minnesota
    1,300
    $133 is alot to drop on one item that is not a motor and ESC though. I think I'll wait on those until I need to replace them or have the extra money.
    ERBE
    30th Grave Digger
    Slash 4x4
    MGT 8.0
  29. #69
    Minnesota
    1,300
    Okay just put in another order
    Hot racing front and rear shock mounts Silver
    Traxxas Blue and purple springs
    Traxxas Red Shock bodies
    Hot racing Silver shock upgrade kit
    Traxxas Red Pushrods
    Red Traxxas Hubs
    New stock skid plates
    Castle Field Link
    So that should also be coming in next week.
    ERBE
    30th Grave Digger
    Slash 4x4
    MGT 8.0
  30. #70
    so cal
    9,245
    good little list!
    i wouldn't consider a savox over a hitec .worth the extra change!
  31. #71
    Minnesota
    1,300
    good little list!
    Exactly why I'm holding off until i need to upgrade my servo.
    ERBE
    30th Grave Digger
    Slash 4x4
    MGT 8.0
  32. #72
    Minnesota
    1,300
    Well just ordered an outerwears, more snow is coming monday! I think I got almost $400 in upgrades already.
    ERBE
    30th Grave Digger
    Slash 4x4
    MGT 8.0
  33. #73
    so cal
    9,245
    that is easy to do!
  34. #74
    Minnesota
    1,300
    Got a question. Does the summit have a bigger receiver box? Mine is so packed and I havent even added the summit bumper wire in there yet so was wondering if the summit had a bigger receiver box?
    ERBE
    30th Grave Digger
    Slash 4x4
    MGT 8.0
  35. #75
    The Netherlands
    504
    Think not, my revo s box is fully packed too. Especially after adding telemetry
  36. #76
    Minnesota
    1,300
    Quote Originally Posted by WesleyK View Post
    Mines so tights the white plastic over the light hole popped out. No longer waterproof.
    Put packing tape on the inside of the box and then put CA glue in the light hole.
    ERBE
    30th Grave Digger
    Slash 4x4
    MGT 8.0
  37. #77
    Minnesota
    1,300
    So I did http://traxxas.com/support/Different...ion-and-Summit to get the rear diff out and I did all the steps but can't get the bulkhead off the chassis let alone get the diff out. How do I get it out?
    ERBE
    30th Grave Digger
    Slash 4x4
    MGT 8.0
  38. #78
    Sep 2012
    Essex, UK
    154
    First time I tried to get the bulkheads out, missed undoing to shock screws...
  39. #79
    The Netherlands
    504
    Uhm, i just take the rear wing mount off, then the pushrods + rocker + springs and remove the screws securing the shocktower at the front of the shocks through the chassis to the bulkhead. Then i disconnect all axles and you should be good to go.
    Especially those screws for the shock tower are important hehe
  40. #80
    Minnesota
    1,300
    Yea that thing said nothing about the shock screws. I got it now. So how do you apply diff grease? Just put it around the gear or do you need to take the diff cup off? Also the guy said he dried up the diffs because he thought it was gonna sit on the shelf for awhile yet there is grease already in there.....
    ERBE
    30th Grave Digger
    Slash 4x4
    MGT 8.0
