Page 10 of 11 FirstFirst ... 891011 LastLast
Results 361 to 400 of 401
  1. #361
    Norway
    290
    Quote Originally Posted by Fr8cture View Post
    Sounds like too much maintenance to me. IMO you shouldn't have to me messing around with a CVD, it should just work, The thing feel out without even doing a single jump....
    It's all part of the hobby. If you don't like fixing things, then you may as well drive virtual RC cars in some iPhone app
    CVDs are not some magic pixie dust that fix problems. They have their pros and cons, though in my opinion, the pros outnumber the cons. And provided you install and align everything correctly and apply liberal amounts of red loctite, things should hold fine.
    I've just come home from a driving session with my Stampede friend, and I've had no problems at all throughout my whole pack (2x760mah 2S). Stampede friend's grub screw came loose again, so I'm inclined to think that it's either a design flaw with Stampede MIP CVDs, or he's using crap loctite.
  2. #362
    Minnesota
    1,306
    Quote Originally Posted by ignis View Post
    It's not that I don't mind fixing things its just that a driveshaft should be something I shouldn't really have to worry about.
    ERBE
    Savage Flux XL
    Trail finder 2
  3. #363
    Jun 2010
    Miami, Fl
    6,731
    it happened to me once, but after the red loctite, and letting it dry for 24hr before use, didn't have any more issues, also it is important to set the screw on the flat surface of the pin. I think I've seen people putting heat shrink over.
  4. #364
    Minnesota
    1,306
    If its not one thing its another, I'm starting to think this really isn't worth it. The slipper is show or something, the gears are meshed they work fine but all it does is sit there and slip the whole time....
    ERBE
    Savage Flux XL
    Trail finder 2
  5. #365
    Jun 2010
    Miami, Fl
    6,731
    Is the slipper tight?, did you check the center driveshaft?
  6. #366
    Minnesota
    1,306
    It has to be the slipper. I ran it and the gears turn but the slipper wasn't. The slipper should be tight but when I try to tighten it it just turns the slipper....
    ERBE
    Savage Flux XL
    Trail finder 2
  7. #367
    Minnesota
    1,306
    So I saw the bearing on the spur is destroyed... Could that be the reason its slipping so much? It still turns but Im guessing thats it...
    EDIT: Problem fixed, stole a bearing from my grave digger. lol
    ERBE
    Savage Flux XL
    Trail finder 2
  8. #368
    Jul 2012
    Saint Louis, MO
    504
    I use the upgraded metal bearings for this as I blew the stock ones up quite often.
  9. #369
    Minnesota
    1,306
    Well ran it today and guess what? Another failure. This time it was the hex in the wheel stripped. Im seriously about to post my truck. I barely even had a chance to run it in the month i've had it. Problem after problem after problem. This one is not a chap fix....
    ERBE
    Savage Flux XL
    Trail finder 2
  10. #370
    Minnesota
    1,306
    I am surprised my 23mm hex's from my MGT fit so I threw those and my MGT wheels and tires on and no problem so far except the wheels are a little soft and skinny that it tips about but finally got some air!
    Sent from my SCH-I535 using Tapatalk 2
    ERBE
    Savage Flux XL
    Trail finder 2
  11. #371
    The Netherlands
    851
    Wow, you really have some bad luck :|.
    I'm at my 15th run or so and except for a broken front bulkhead, and a bent pushrod its still going strong.. I hope you will get it fixed!
  12. #372
    Minnesota
    1,306
    It's working but these tires suck lol
    ERBE
    Savage Flux XL
    Trail finder 2
  13. #373
    Minnesota
    1,306
    Wow looks like I'll need a new shell in no time, really disappointed.
    ERBE
    Savage Flux XL
    Trail finder 2
  14. #374
    Jul 2012
    Saint Louis, MO
    504
    I went back to my revo body and wing to prevent flip overs. The summit body after 2 wheelie flips resulted in the same road rash and hole.
  15. #375
    Minnesota
    1,306
    Quote Originally Posted by tjtoed View Post
    I expected the road rash but the holes really make me mad. Anyways I put my revo up on another forum MP...
    ERBE
    Savage Flux XL
    Trail finder 2
  16. #376
    15,877
    Hard to do that with the wheels on the ground.
    Alt-248 on the number pad =
  17. #377
    Minnesota
    1,306
    Yeah but for the amount of time I have driving my revo it's disappointing.
    ERBE
    Savage Flux XL
    Trail finder 2
  18. #378
    15,877
    The amount of time spent on the lid? I can only imagine.
  19. #379
    Jun 2010
    Miami, Fl
    6,731
    If you lower the wheelie bar, it should flip less. Also shoe goo, and drywall tape works good reinforcing the body.
  20. #380
    Minnesota
    1,306
    Broke the wheelie bar today.
    ERBE
    Savage Flux XL
    Trail finder 2
  21. #381
    The Netherlands
    851
    I'm starting to wonder what kind of torture you are putting your car through
    Except for a front bulkhead, 1 pushrod and the stock tires, i'm still on stock parts after 15 runs or so, everything still seems fine.
  22. #382
    Minnesota
    1,306
    Tbh, today was the first time the truck was off the ground....thats why im very unhappy about it.
    ERBE
    Savage Flux XL
    Trail finder 2
  23. #383
    The Netherlands
    851
    Mine spends a lot on his lid or cartwheeling or jumping and crashing on his nose etc.
    Is it still cold at your place?
  24. #384
    Jun 2010
    Miami, Fl
    6,731
    oh, I've seen it for sale on another forum. I sold my erevo, but keeping the emaxx it is my fav.
  25. #385
    Minnesota
    1,306
    Quote Originally Posted by WesleyK View Post
    Not that cold like 30 to 40
    Yea, I doubt it will sell as I'm asking alot but I'm still unsure if I want to sell it.
    ERBE
    Savage Flux XL
    Trail finder 2
  26. #386
    Minnesota
    1,306
    Another good day
    ERBE
    Savage Flux XL
    Trail finder 2
  27. #387
    Jun 2010
    Miami, Fl
    6,731
    speaking about bad luck...there is always something wrong with your truck.
  28. #388
    Minnesota
    1,306
    Yeah, lucky it didn't melt the chassis.
    ERBE
    Savage Flux XL
    Trail finder 2
  29. #389
    Jun 2010
    Miami, Fl
    6,731
    that's good, how's the esc? what happened exactly?
  30. #390
    Minnesota
    1,306
    Just lost power and then it started smoking. Thought it was the ESC but it was the battery, the other one is fine. I haven't tested the ESC since it just happened but it should be fine. The battery melted right off the cable.
    ERBE
    Savage Flux XL
    Trail finder 2
  31. #391
    The Netherlands
    851
    Woah, i thought it couldnt get worse , fortunately your car still seems to be fine.
  32. #392
    Minnesota
    1,306
    Woah, i thought i couldnt get worse , fortunately your car still seems to be fine.
    Yeah I gotta clean out the battery box but now I don't got any battery's to run.
    ERBE
    Savage Flux XL
    Trail finder 2
  33. #393
    Minnesota
    1,306
    Well as you expected Rc-Fan the ESC is shot too and I lost my other gens ace lipo testing it....
    ERBE
    Savage Flux XL
    Trail finder 2
  34. #394
    Jun 2010
    Miami, Fl
    6,731
    Wow..that's bad news, is it a mmm2 you can get it fixed for 85 unless still is under warranty. I sent one to castle, and two days later the replacement was on the mail, castle is great.
  35. #395
    Minnesota
    1,306
    No its either a gen 1 or gen 2 MMM
    ERBE
    Savage Flux XL
    Trail finder 2
  36. #396
    Jul 2012
    Saint Louis, MO
    504
    New hobby? I am sorry but the amount of bad luck you have, I'd be done.
    Was this a new car or used or did you build from scratch? Was the esc wet?
  37. #397
    The Netherlands
    851
    It was used if i remember correctly. Yep, i'm sorry to see the amount of bad luck you have
  38. #398
    Minnesota
    1,306
    Yes its used I just started after christmad ans have 4 rc's this is the only one where I've actually have parts break without running the thing. Im pretty much convinced that I'm cursed or something. Theres no way I have the money to fix it now for everything that is broken $300 plus $100 for new lipos.
    ERBE
    Savage Flux XL
    Trail finder 2
  39. #399
    Minnesota
    1,306
    Well since I'm broke and to fix my revo it would cost like $300 I decided to try to trade my slash for a e-revo and just use that chassis and move my upgrades and have my current revo as a roller until I can fix it or possible sell it. I'm not too into SCT's anyways. They don't give the excitement a revo does.
    ERBE
    Savage Flux XL
    Trail finder 2
  40. #400
    Jul 2012
    Saint Louis, MO
    504
    Yeah. I agree the 1/10 revo platform is great. I am looking to get a summit and then sell off my hopped up p4de.
    I like the chassis layout and working on them is fun.
