Page 5 of 5 FirstFirst ... 345
Results 161 to 199 of 199
  1. #161
    15,577
    Quote Originally Posted by chardur View Post
    I noticed they have a 7200mah 70c pack now. Any one know if it fits the summit? If so, would the stock summit with its brushed motor even use the extra output?
    http://spcracing.com/index.php?productID=126
    PACK DIMENSIONS: 138.5mm long x 46mm wide x 24.5mm deep
    It's a standard 2S hardcase size. It will fit.
    Is the 70C strictly needed in a brushed Summit? No. Is it a waste? No. Greater C-rating = less voltage drop and less stress on the pack. Also, those of us who also have brushless trucks, especially the big ones, will have one pack to use across the platforms.
    Alt-248 on the number pad = °
  2. #162
    Jul 2012
    Nowhere, Québec, Canada
    398
    This battery is 2.5mm wider and 2mm taller. Also it's a hardcase battery, I'm not sure...
    ... for the fun of excess!
  3. #163
    Oregon
    70
    Feeling good about now . four SPC 8200's parallel charging
  4. #164
    Sep 2012
    sacramento, ca
    742
    Quote Originally Posted by bwill11 View Post
    That's a great sight! Love my icharger.
    addicted much....
  5. #165
    Portugal
    409
    That balancer permits you charge 4 baterys balanced? What brand and model is that balancer? please link it...
    thanks
  6. #166
    Jul 2012
    Saint Louis, MO
    504
    Quote Originally Posted by targetingxmod View Post
    thanks
    I have the same one and it will do 6. Progressive RC.
  7. #167
    Oct 2012
    Canmore, AB
    328
    The charger is not what allows you to charge 4 or 6 batteries. Is the parallel charging board that does. However, with 8K-class lipos, you need alot of amps to charge them at the recommended rate (1C). To charge those 4 SPCs8200s at 1C, you would need 32.8 amps, not many chargers out there can deliver that. The 206B is a great charger, but its max output is 20amps. It can charge those 4 or even 6 batts, but because you are not charging at 1C your charge times will increase. I use the same setup as bwill11, when I parallel charge two 8200s it takes about 30-35mins (from storage voltage). I've never hooked up 4 or 6 but I am wondering how long it takes to charge them? bwill11?
    Working hard to appear reasonably sane.
  8. #168
    Oregon
    70
    Just recieved this set up for my birthday. At the time of the pic I was charging all four from storage voltage, then discharging back to storage just to get a cycle on them. Fairly fast from storage to peak voltage, about 5 hours from peak to storage. I had the amps set very low for storage though. I figured i didn't need the thirty (306b) amp charger, because I will only be charging two batteries at a time normally. From cut-off voltage, I expect charge time about 60-70 min for all four. Just a guess though. All my speeds controls are at Traxxas right now. Getting two upgraded to LVC and 1 LVC is getting repaired/warrantied. So no use of super cool new batteries or charging station . targetingxmod go here http://www.progressiverc.com/the-ste...00w-combo.html i figured it was the cheapest way to charge more than one high capacity Lipo.
  9. #169
    Alma, MI
    12,281
    2 8200's from LVC to full: ~35 minutes
    2 8200's from storage to full: ~17 minutes
    3 8200's from LVC to full: ~52 minutes
    3 8200's from storage to full: ~26 minutes
    4 8200's from LVC to full: ~69 minutes
    4 8200's from storage to full: ~35 minutes
    5 8200's from LVC to full: ~86 minutes
    5 8200's from storage to full: ~43 minutes
    6 8200's from LVC to full: ~104 minutes
    6 8200's from storage to full: ~52 minutes
    All being balance charged at 20 amps with an iCharger 206B being fed 24 volts.
    I have created an Excel spreadsheet that calculates this for me... it is not 100% accurate due to the balance process, but it gives a very close approximation. The formulas take into account the efficiency of the charger (90%+ for iChargers), state of discharge, amperage, C rate, cell count, % of discharge, cost to charge... pretty much everything but how far out of balance the cells are.
    Just a little more info...
    COST to charge:
    2 8200's from LVC to full: ~.016¢
    2 8200's from storage to full: ~.008¢
    3 8200's from LVC to full: ~.025¢
    3 8200's from storage to full: ~.012¢
    4 8200's from LVC to full: ~.033¢
    4 8200's from storage to full: ~.016¢
    5 8200's from LVC to full: ~.042¢
    5 8200's from storage to full: ~.021¢
    6 8200's from LVC to full: ~.050¢
    6 8200's from storage to full: ~.025¢
    This cost will vary based on your location due to fluctuations in the cost of electricity.
  10. #170
    Oregon
    70
    My guess for a four battery charge time was pretty accurate- Thanks for that ego boost Jimmy . It's killing me right now to not have a running truck. Poor planning on my part.
  11. #171
    Alma, MI
    12,281
    No problem!
    Traxxas is usually pretty quick with the turn-around... you should be back to RC'n in no time.
    Also, discharging can be done quicker with regenerative discharging or adding an external in-line load with the iCharger... I have not looked any further than that though, so that is all the knowledge I can give.
    I ended up building a separate stand-alone discharger to run my batteries down when needed...
  12. #172
    Oct 2012
    Canmore, AB
    328
    COST to charge:
    Awesome! Thanks for sharing that.
    Overall I'm very happy with the 206B...but I sure wish I had gotten the 30amp model!
  13. #173
    15,577
    Quote Originally Posted by Captain Switchblade View Post
    I can imagine. I hit the 40A limit on my PL6 today. I joked with a friend about needing a bigger charger. I think 60A would be sweet. My 24V PSU was only pushing 15+ amps.
    So I guess I could just get another PL6...
    I don't get how the $50, 50-watt battery cooker guys do it. (Nor why, but that's a different topic altogether.)
  14. #174
    Alma, MI
    12,281
    Agreed.
  15. #175
    Riverton Utah
    4,351
    I'll bump this thread up. Looks like they should be back in stock in early July.
  16. #176
    Jun 2013
    Idaho
    150
    COST to charge:
    This is awesome.
    Sent from my iPhone 4
    Summit
  17. #177
    Alma, MI
    12,281
    That is a LOT of math.
  18. #178
    15,577
    Or early August, 2013........they're baaaaack!
  19. #179
    Aug 2013
    Seattle, WA
    42
    Man those are cheap. Just ordered a pair. Recently I paid 64 each+ tax for 5000mah at local store....
  20. #180
    Jun 2013
    265
    Postage for 2 x 8200mah 2S lipos to Western Australia = $105.
    Yep postage is $5 more than the cost of the two batteries!
  21. #181
    Dec 2004
    3,652
    Quote Originally Posted by ErbeSumm View Post
    Blame UPS as that is what they charge.
  22. #182
    15,577
    You could always move...LOL.
  23. #183
    Jun 2013
    265
    Quote Originally Posted by Jakey View Post
    Yeah I know but it completely ridiculous!!
  24. #184
    Sep 2009
    Victoria B.C Canada
    5,119
    If it makes you feel better i payed 25 shipping and another 46 at the door
    The guy that robbed me was dressed in brown and drove a brown money van whoops delivery van. lol
    And I'm on the same continent.
    Sent using lipo power
    Mountains cant stop me
    they have tried
  25. #185
    Feb 2013
    PARKER COLO
    784
    I would still buy them at that cost. I have priced other lipos of approx the same mah at LHS here in the states and they were $90 to $100 a piece. These are really good batteries, you wont regret buying them. I ran with my grandsons over the weekend along a train track, we walked an hour out and an hour back and I was only down to 3.6 volts, probably could have gone another 20 mins or so. I wonder what happens to the shipping price if you buy more. Maybe there are some other Aussie's that would help with the shipping and spread the cost.
    "Better Old and Devious than Young and Exuberant"
  26. #186
    Aug 2013
    Seattle, WA
    42
    I paid $6 for shipping This morning and its already shipped and will be here in 2 days.....Another reason this forum rocks. Woulda never known about these....
  27. #187
    Feb 2013
    PARKER COLO
    784
    The last set of batteries I bought for my grandsons summit vxl, there was 8 one dollar bills and 65 cents in the package. The freight was less than paid for so he refunded my money. Tom did not need to do that and I would have never noticed. Honesty is hard to find any more. When I need batteries is SPC, even if I have to wait.
  28. #188
    Aug 2013
    Seattle, WA
    42
    Honesty is making a come back. I own a small business and 100% honesty, even when I loose money, is a company policy
  29. #189
    woodstock .on.canada
    2,194
    hey guys guess what revolectrix just released the power lab 8x2
    full 40 amp per port!!!!!!!!!(80amp's of charging power)
    4 spc' in under 1/2 an hour!
    exciteded
    summit /mustang /stampede-2s spc lipo
  30. #190
    Aug 2013
    Seattle, WA
    42
    Quote Originally Posted by reod12x2 View Post
    exciteded
    $370 is too much for me to charge batteries. I just got a $119 Onyx 245 and it charges them in about 45 minutes.
  31. #191
    Dec 2004
    3,652
    Quote Originally Posted by seamonster View Post
    8.2 Amp-Hr / 5 Amp = 1.6 Hr or 1 Hr & 38 Min and this does not take into account the CV portion of the charge cycle. So in reality expect charge times approaching 2 hours if the packs are near empty.
    Edit: This is not a support-type post, but rather a simple math fact regarding charge times.
  32. #192
    Feb 2013
    PARKER COLO
    784
    I know that with my Hitec x4 it charges at a rate of 6 amps maximum and from storage mode at 3.8 volts it takes abut 45 to 60 minutes to fully charge the 8200mah batteries. It takes a little longer than an hour and a half to fully charge from 3.4 volts when the batteries have been fully discharged. So your Math formula is correct in my case.
  33. #193
    2,059
    THERE BACK!!!!
    But there's only 18 left. Its amazing how the spc 8200 and the smc 9400 come in stock at the same time
    I "donated" a great pair of spc 8200 to my friend, so this time I purchased a set of smc 9400. Now the wait begins
    MAN, Use Common Sense
    Funky Gecko, SumVee HDE
  34. #194
    Nashville, TN
    1,783
    I tried ordering one yesterday. It said they were in stock and let me add it to the cart. But once I tried to check out, it said they weren't in stock. Sadness.
  35. #195
    15,577
    Quote Originally Posted by Jws1982 View Post
    I'm almost positive they are still in stock. I suggest you call them. They're really nice!
  36. #196
    Jun 2014
    I had this same problem last night but I can confirm that the problem seems to be fixed. I ordered two this morning.
  37. #197
    Jul 2012
    398
    how are SMC 9400 compared to SPC 8200 ? Do these fit in the summit/revo?
    I currently own a pair of SPC for my summit and they're pretty awsum
    EDIT: SMC don't ship to canada ;-;
  38. #198
    Sherbrooke Qc, Canada
    160
    You can order them from right here in Qc. http://begoracing.com/shop/index.php...roduct_id=1043.
    Tekin powered Summit
  39. #199
    Jul 2012
    398
    Quote Originally Posted by Jimmy1971 View Post
    this is NICE thank you jimmy!
