Results 1 to 21 of 21
    Feb 2013
    7
    Talking 1/16 summit to 1/16 revo
    Making my 1/16 summit into a 1/16 erevo
    here is the list
    a-arms:front and back
    rockers:front and back
    drive shafts:all four
    toe links
    push rods
    any help is appreciated pics coming soon!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!
    Alma, Michigan
    12,291
    Front arms are the same.
    You can use the Summit axles until they break... the are the same length.
    Toe links and push rods are the same.
    Basically the only difference between the two are the body posts, body, rockers, rear arms, and gearing.
    393
    bumpers and wing too
    Alma, Michigan
    12,291
    Ah, yes. Bumpers and wing.
    Feb 2013
    7
    really ur sure the links and rods are the same i thought they were longer seing as how they have to conect to longer rockers
    and if i get extended rear for the revo is it the same as the summit or is it still different
    Alma, Michigan
    12,291
    The extended arms are the Summit arms. They fit all Traxxas 1/16ths.
    The rods are the same... if you look on them they say P2/LT. The Revo rockers are P2. The Summit rockers are LT.
    If there was a difference the rods would be shorter for the Summit, not longer.
    Feb 2013
    7
    oh ok the links too so all i need to change really is the rockers do the rockers change the suspension that much how can a 1 inch part drop the car like 5 inches
    Pittsburgh, PA
    662
    Quote Originally Posted by mr._1-16_merv-umitt View Post
    It doesn't drop it 5 inches, maybe a inch inch and a half max. The pic below is of a full (minus bumpers) Summit to Merv conversion. It sits just bit lower even when I put the summit wheels on it.
    Feb 2013
    7
    thanks soo much what did u change on yours
    Pittsburgh, PA
    662
    Just body, body mounts, wing, wing mount, P2 rockers 23 tooth pinion and TRX CVD's. The Summit already had Merv RPM A Arm and TRX aluminum push rods/toe links s when I bought it.
    Feb 2013
    7
    front and rear merv arms? and are they merv push rods and toe links or summit rods and links
    Pittsburgh, PA
    662
    Yes front and rear. The fronts aren't necessary as they're the same as the summit anyway. I put RPM on all my rigs so they would've been switched regardless. The TRX aluminum toe links are made for the Merv/Summit they both use the same rods links, it doesn't matter what the pkg says they're identical.
    Feb 2013
    7
    so all i really need to change is rockers body and wheels and add a wing? also can i use summit axles on a merv and merv axles on a summit? thanks so much sorry for all the question so a comple list would be p2 rockers,revo body,revo wheels,wing and mounts, and arms? basically these truckes are exactley the same except for the rockers body and wheels
    Alma, Michigan
    12,291
    1st question: Yup
    2nd question: See post #2
    3rd question: All except for the front arms.
    Feb 2013
    7
    have you used the merv axles on the summit before
    Pittsburgh, PA
    662
    Yes many times. I even had 3 summit axels and one Merv axel on mine at one point before I got the CVD's.
    Baton Rouge, LA
    1,066
    Does the change make it more drivable? Is this the same process for the mini Slash aside from the obvious pieces like body, wheels, bumpers, etc.?
    / 16
    Alma, Michigan
    12,291
    The Slash would need rods, links, axles, arms, gearing, tires, wheels, body, body posts, bumpers...
    I would check the exploded views of each to double check.
    Baton Rouge, LA
    1,066
    Gotcha...appears they must have differing track widths...didn't realize that.
    / 16
    Feb 2013
    17
    The shock pistons in the summit are different than the e revo the are red and have a smaller holes much better than the black e revo pistons in my opinion
    Feb 2013
    17
    [IMG][/IMG]
    Look closely the black ones are bigger.
