    191
    Does this crank port look ok
    Does this look ok or is it no good?
    Feb 2013
    Burnt fork, Wyoming
    66
    what I found works best for shaping steel in a tungsten carbide bite followed with a grinding stone... I am no pro but i would try to make both sides the same to try and make it as balanced as you can other then that not bad for a go at it.
    191
    So do the same to the other side and yeah it some tough steel i did it with a small file
    Jun 2010
    Miami, Fl
    6,731
    Not sure how exactly should it be, but it doesn't look close for what I've seen before, look at this
    http://traxxas.com/forums/showthread....3-engine-mods
    Oct 2005
    South Florida
    18,537
    You've done a light porting on the crank it should be OK but I'm sure you realize that crank is pretty hard metal.... Here's the porting thread I put together.
    http://traxxas.com/forums/showthread...hlight=porting
    Robin Williams
    He will be greatly missed...
