Results 1 to 18 of 18
    Riverton Utah
    4,343
    Lipo Use/Care Questions
    Hey guys, I'm about 99% sure I'm going to get lipos for my Summit here in the next month, so I have a few questions. I'm not sure I understand fully how to care for and use lipos, so I'll just say what I know, and if I'm missing somthing, or somthing inncorrect, PLEASE let me know.
    Never drain them past the low voltage, always use LVD.
    If you don't use them for at least 3 days, put them in storage mode, at 3.8 volts to prevent damage.
    Never over charge them, or short them. (DUH!)
    If it puffs up, stop using it.
    You can charge them at much higher charge rates. (6amps?)
    Always balence them while charging.
    Ok, now here's some questions.
    I have the Traxxas EZ Peak Plus, and the lipos I'm going to get are the SPC 2s 8200mah lipos. Can I charge them both at the same time (using the dual lipo charger thingy) at 6amps? Also, can I balance charge them at the same time? If I'm done using my Summit after it hits LVD, do I need to charge the batterys as soon as I can, or can I wait a day or so to charge them and not hurt them? If I only charge it partly or a little bit, is it safe to leave them for a day or so with a "random" charge on it? Anything I'm missing? I want to know EVERYTHING there is to taking care of lipos. Thanks!
    198
    2s 8200 sounds good i use 2 2s 5200 and get a 45 min run time. thats running it hard the whole time. with no heat from the motor or esc as for your q n a. i dont know i charge mine use it let it sit at what its at or full charge then let it sit foir days never had a problem. and had them for like a year. u heed one the of the pros on here to chime in. but good luck.
    California
    4,840
    https://sites.google.com/site/tjingu...arging-how-tos
    check that out read about lipo safety and how to charge and how to parallel charge. This will help with what you need.
    DEU 8:18 ESV
    Michigan
    4,855
    They say don't do this ,so if I were you don't,but I leave my lipos fully charged for two or more months with no ill effects, In fact I have a brand new Reedy 6500mah 2s 65c bought it charged it,intending to use it,but never did.
    I personally think the most important thing,is to not store them with out at least half a charge,as they will slowly lose charge on their own.
    This is just my opinion,just because i have never had issues leaving them charged,doesn't make it right. and I am in no way a lipo specialist.
    Feb 2013
    6
    Your trashing your lipos by doing this.
    A lipo should never be kept at full charge for more than a couple of days. Otherwise at full charge, overtime the internal resistance of the cells will break down from too much voltage being stored in them.
    I mentioned this in another thread, but lipos are something I'm familiar with from flying rc helicopters. My 700 runs on 12s and those batteries are not cheap at 150 a pack (and you need 2). All my lipos show no signs of puffing and after 200+ cycles are still going strong. Below is how I handle my lipos to ensure they last me.
    Never keep charged longer than 3 to 4 days max.
    Never discharge lower than 3.7 volts, on 2s I set my tqi to beep at 7.5 Volta, battery comes off with about 20% left which is perfect. Over discharging a cell can damage or kill it.
    Always charge at a safe c rating. My gens ace are rated for 5c,I charge at 2C and never more than 3c. Depending on your charger you may need to charge at a lower c rating, depends on what the battery can handle and how many amps the charger does.
    Store your lipos at storage charge when not in use, 3.8 volts per cell. Keep them stored in a cool dry place.
    If you follow these tips your lipos will last you a long time. A cell checker is another great tool so you can check your batteries at a glance. Also a good balance charger and power supply is key. A good charger will balance charge your lipos and keep the balance of the cells in check. I'm an Icharger fan and have the 306b with 1000w ps. That's overkill for you situation unless you parallel charge.
    Buffalo NY
    1,330
    Only charge at greater than 1C if the battery manufacturer says its okay (i.e., it's printed on the label). Understand, though, that even if a manufacturer says it's okay to charge at 2C (or more), it can shorten their useful life. That's why personally, I've always charged every pack I own at 1C, regardless of what the label says. You have a nice little multi-port charger, so there's really no need to "fast charge" em. My $.02!
    (Enter Jimmie Neutron, who will probably disagree with me...)
    Buffalo NY
    1,330
    Quote Originally Posted by Gawl View Post
    Your trashing your lipos by doing this. A lipo should never be kept at full charge for more than a couple of days. Otherwise at full charge, overtime the internal resistance of the cells will break down from too much voltage being stored in them.
    ^^^ Listen to this man. The only LiPo I've ever puffed was stored at full charge for months.
    Ontario
    989
    I have those same batteries and charger with the dual charger thing
    They last forever lol, I haven't even got them below 3.80 yet, I just end up getting bored after about 45 minutes
    dual charging them from 3.8 at 6 amps (3 amps each) takes a little over an hour so from 3.5 it would take about 2 and a half hours
    What's a coffee if it aint Irish
    Oct 2012
    Canmore, AB
    327
    So, what is the recommended proceedure if you do have a puffed up lipo? From what I gather: Discharge it (but not using the discharge feature on the charger?). Sink it in salt water for a few days. Chuck it.
    Anyone with good advice on this?
    Ontario
    989
    there are places that safely dispose of batteries, not sure if it's free or a few bucks but that's the best way
    Buffalo NY
    1,330
    Quote Originally Posted by Captain Switchblade View Post
    I've heard about the saltwater thing, but it's kinda silly IMO. Discharge the pack as much as you can, then throw it away in the trash. That's how I disposed of my puffed LiPo.
    Was that wrong?
    Alma, MI
    12,280
    No, not wrong.
    The purpose of the salt water bath is to make sure they are fully discharged. This can be done with an automotive light bulb too. Once fully discharged they are safe to do whatever to them... as in they will no longer flare out.
    Riverton Utah
    4,343
    Ok, thanks guys! Dumb question, what voltage does the EVX 2 on the Summit stop at?
    Alma, MI
    12,280
    For me:
    Stage 1 3.6
    Stage 2 3.4
    Riverton Utah
    4,343
    For me:
    Stage 1 3.6
    Stage 2 3.4
    Ok, that sounds really low to me... Is it ok to run them that lowq normally? I'm, guessing so because Traxxas made it that way...
    Alma, MI
    12,280
    That is per cell... not low at all.
    Damage does not occur until 3v/cell.
    Riverton Utah
    4,343
    Oh. LOL, ok. Thanks Jimmie, you always seem to know how to help!
    Oct 2012
    Canmore, AB
    327
    No, not wrong.
    Great, thank alot
