Results 1 to 4 of 4
    Question Hot Racing Aluminum Rear Bulkheads: Shim Issue
    So I crashed my MERV pretty hard a couple weeks ago: it broke the back of the chassis, as well as the two rear bulkheads. I bought the Hot-Racing rear aluminum bulkheads to replace the originals with, and used a small steel brace and JB-weld to fix the broken chassis.
    The new bulkheads fit great; my only problem is I don't know how many shims to add to the diff. I added one shim (the kit came with 4), but now that the car's back together, I can hear those gears click if I go hard on the throttle.
    I tried contacting Hot Racing to ask their opinion, but never got an answer. Does anyone have any idea how many shims I should use, or a way I can tell how many it needs?
    Thanks!
    Indiana
    733
    I had to put only one in my summit on the front and back, I tried two but when I put it together and turned the center drive shaft it felt like it was binding so I took one out and it felt smooth. thats about my extent of knowledge for this sure others have more.
    Let's Go Steelers!!!... KCCO
    9,244
    They are all different. When shimming add a few shims and bolt it together with the skid plate and brace onto the chassis. and turn the pinion. If it binds remove a shim and bolt.it up again. If it turns easy add another shim and do the same. . If its clicking don't drive it and pull it apart. You.might be able to save it
    I would look into a new chassis pretty inexpensive on ebay
    Thanks for the advice: adding one more shim did the trick
