Results 1 to 13 of 13
Thread: 70/30
    185
    70/30
    When I flipped 70/30 on my tx, the reverse throttle is too sensitive. Should I set the expo rate?
    Alma, MI
    12,281
    Did you reprogram your ESC after you switched?
    185
    I recalibrated, after switching 70/30.
    Ontario
    989
    sorry to cut it but how do you do this? I forget and can't find it in the manual.. just a page number will do if you could
    What's a coffee if it aint Irish
    Ontario
    989
    What does that have to do with anything?
    sorry I know how to re-calibrate, I don't remember how to switch to 70/30 properly
    Norfolk, va
    1,167
    Quote Originally Posted by TQi View Post
    My TQi transmitter has a lever that switches between 50/50 and 70/30, you just move it and the trigger changes position.
    ERBE, ERBE, Summit, Slash 4X4, Bandit,
    185
    Quote Originally Posted by RC-nightmare View Post
    I recalibrated and still the reverse is very sensitive.
    Earth
    429
    Urghhh okay set it to 70/30
    when you turn the ESC on, you have to press the button and hold it down the entire time, when it flashes once pull the throttle to make the car go forward then when it flashes twice push it in full reverse after it stops blinking i think it turn green let the throttle go and i think that is it just turn it back on if its not and it should be set it might take a couple of tries and make sure your trim is set to the middle i did the same thing to mine!!!
    589
    its going to be sensitive in that setting. because only 30 percest trigger travel = 100% reverse. instead of 50 travel = 100 reverse.
    185
    Still having problem even the throttle trim is center. The only way is set the throttle end points. I think I don't want to take that chance.
    Earth
    429
    Is it Possible to just leave it how it is!!btw it is 70% foward travel and 30% reverse travel. either your not doing something right or i am not giving you enough info!! can you do a video of what it is doing and stuff then i am pretty sure i can help you more!!!
    Ontario
    989
    Right on thanks, I forgot I have to do that with a mmp, might be a little different
