Page 3 of 4 FirstFirst 1234 LastLast
Results 81 to 120 of 158
  1. #81
    Jul 2010
    441
    they dont bend to easily
    but i think they are hollow inside
    i probably have bent 4 in a year
    but i can say ive never shimmed a diff and im running 6s with losi diffs and losi axles and kershaw centre dogbones and have not broken any parts of driveline for over a year and even before then i only broke one std diff in one year
    i do abuse my truck but i dont abuse it for 10 minutes straight most of time i give it in small bursts and then cruise abit
    then abit more and when i do top speed runs i think i give it afew long high speed runs then cruise it abit
    u cant straighten them back out but its easier to buy new set
    way ive done mine is ive used losi hubs and got 5mm extra track each side
    that way i didnt have to redrill the hole for the pin
    but i havnt been using mine lately due to tqi problems
    but i now have parts to fix just kids dont let me have spare time and i got a new ps3 game
    which stops me spending time on car hehehe
  2. #82
    la porte
    689
    Thanks for the input I'm playin black ops 2 now lol
    6S OR NOTHING............................ maybe 5s
  3. #83
    Jul 2010
    441
    I'm playing fallout new vegas
    But play black ops 1 and 2 with my 5 year old
    He loves it
  4. #84
    la porte
    689
    Sorry moderators for the off topic stuff
  5. #85
    la porte
    689
    my lst cvds came in today and i got them put on just need a drill bit to redrill the holes for the hexes
  6. #86
    la porte
    689
    i just beveled the edges that way i could press in the bearings
  7. #87
    la porte
    689
    quick question at what rate do you guys charge your lipos i charge my 3s 5000mahs at 5 what do you guys suggest
  8. #88
    so cal
    9,244
    Depends on the C rating of your batteries but you are at 1c so your good
  9. #89
    Jul 2010
    441
    i charge at anything from 5 to 8 amps
    let me know if yr losi axles pop out
    i need to look for a cure for mine
    friend just fitted losi diffs but he got other expensive cvds
    but i think they are for std revo hubs so they are not the 8mm diameter
  10. #90
    Jul 2010
    441
    insrtead of redrilling the holde i just added washers to give me 5 or so mm extra track each side
    less mucking round when i need to replace the axles
  11. #91
    Aug 2012
    Central NJ
    1,245
    Its all on the battery specs. If Im in no hurry I generally go for 5amps too. My packs are rated for 5C charge rate so with 5000mAh thats 25 amps. I charged them a couple of times at what my charger can handle just to see how well they did and got two packs charged at 20amp rate at the same time in 12 minutes. They fell short on run time by a few minutes charging them fast. If Im running for a long time and dont want to carry a bunch of packs I charge them at 10 amps balanced which takes about the same time it does to charge as it takes me to run out a set of charged packs, pit, swap packs, put discharged packs on charge and go back at it.
  12. #92
    la porte
    689
    ya i considered it but id rather just have the 1/2" offset on my wheels
  13. #93
    la porte
    689
    Not really liking the lst2 shafts the continue to pop out guess I will be going with summit shafts see how we'll the hold up hope they help out a lot because this whole driveshaft issue is starting to make me not like this truck anyone have summit long shafts for sale
  14. #94
    so cal
    9,244
    my summit shafts have been holding up well . check ebay
  15. #95
    la porte
    689
    Good to hear what kind of life span do they have. I'm thinking I should have gone that route in the first place like Mitch recommended
  16. #96
    495
    they last a long time.just make sure you clean the dirt out of them and keep them lubed.i learned that the hard way.i use wd 40 to clean and lube them.i do it about once a month
  17. #97
    Jul 2010
    441
    ive spaced my bearings so that the lst2 axle sits in the diff cup just enough
    but one side normally pops out more than the other but this is like once every 2nd charge of batteries
    i had a look at those expensive axles someone had a link on here the other day and they had a rubber boot
    over that end not sure if a boot will help
    i had a chat with another friend with a heavily modified erevo and he recons if u limited the shocks or the suspension from going to full droop that would help abit
    i think on full droop is when the axle pops out most fo the time
    apart from the axles popping out sometimes ive never snapped one
    end of the day there is no 100% fully reliable easy to fix cure for diffs and axles on this truck
    i just carry a small set of tools in a backpack each time i go out
    and having true track rear end fixing a popped out axle is really easy as it rarely happens on front
  18. #98
    Jul 2010
    441
    also im more annoyed of the bearings and hubs just cant cope
    i have steel losi hubs and there is slight play in the hub to losi axle
    then u have bearings which last afew weeks then they have play cause im lazy to clean em hehehe
  19. #99
    la porte
    689
    Ordered some summit shafts on eBay hope this will be the end of the drive shaft issues
    also just ordered 6 5000mah 2s 50c packs it will be the first time the truck has ever seen 4s
  20. #100
    la porte
    689
    What should I use for gearing on 4s I don't want any heat issues at all but I also don't wanna be slow as molasses lol
  21. #101
    kansas
    7,894
    2/2s
    20/54 good for high 40 mph
    21/54 good for low 50 mph
  22. #102
    la porte
    689
    cool thamks and the temps will be good with 20/54
  23. #103
    so cal
    9,244
    With the losi mod you lose about 4 teeth on the pinion. Right now I mainly run 4s and 24/54 gearing so you can do 22/54 but maybe good for low 40's with the losi diffs
    Stock diff 20/54 low 40's and would take 24/54 to hit low 50's
  24. #104
    la porte
    689
    Thanks man we have pretty similar setup a so. You like 24/54 ill give it a shot
  25. #105
    so cal
    9,244
    On 4s you should be good. I do dirt and hills and street no long grass or anything like that
    You know how it goes just check your temps first ride to see how it goes
  26. #106
    la porte
    689
    so with all these batteries i have, i need a better way to charge all of them i have an onyx now but i would like to be able to charge multiple packs at the same time what is everyone else using any good suggestions
    thanks
    brett
  27. #107
    so cal
    9,244
    with parallel charging you lose the balance charge feature. ok once in a while but not all the time.
    i would go for an icharger and decent power supply
  28. #108
    la porte
    689
    ok i thought there were chargers designed to charge multiple packs while balancing
  29. #109
    Mar 2013
    399
    i have to icharger 206b and i love it.i charged from storage 6 2s spc 8200 mah in an hour and 12 mins.almost wished i had gotten the 3010b thats 30amps
  30. #110
    so cal
    9,244
    I have the 3010 great charger!
    Nope I now only parallel charge when I forgot to charge them.up and am in a hurry
  31. #111
    la porte
    689
    Looks like that's what I will get I'm in no hurry so I guess I'll just charge them as singles
  32. #112
    la porte
    689
    thank you mail man
  33. #113
    Australia
    3,259
    Sweet mate....
    Rock n Rolla !
  34. #114
    la porte
    689
    yep im ready to test them they are much beefier in person they are very stout as far as all the hardware. i tought those pins looked small in pics but in person they a much larger
  35. #115
    Australia
    3,259
    They are much easier to work on too when the break or need replacing.
    Rock n Rolla !
  36. #116
    la porte
    689
    ya i sure wish i had gone this route from the start but oh well
  37. #117
    la porte
    689
    Just got back from a good bashing tried out all my different tires and IMO the trenchers are terrible I love my badlands and my mashers but the trenchers were so unstable and to tippy feeling they were good at speed runs but that's about it
  38. #118
    Australia
    3,259
    The Trenchers do well on my Summit but not my eRevo...its probably my driving style too .
    Rock n Rolla !
  39. #119
    la porte
    689
    Ya I did a little crawling with them and it wasn't bad but trying to do high speed jumps and hard bashing it was like driving suburban compared to a sports car
  40. #120
    la porte
    689
    whats an upgrade that cost $75 or less i want to buy something for my truck but cant think of anything else to upgrade any ideas
